how much boost for hyperkraptic pistons? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 04-10-2007, 07:55 PM Thread Starter
Trader Feedback: (48)
how much can they handle? i have a 351 .30 over
showoff is offline
post #2 of 8 Old 04-10-2007, 10:40 PM
My old stock motor '95 GT took 13psi from my intercooled P1SC.....When I traded it off, it had 103,000 miles on it....Only the last 10,000 miles was on boost.....Never gave me any problems....Can't really say for sure with yours, every motor is different.....What one motor lets go at doesn't mean that the next would at the same boost level......If you have a REAL safe tune, I'd say no more than 11-12psi......
TFScoupe is offline
post #3 of 8 Old 04-11-2007, 03:48 PM
TurboJunky's Avatar
I had a set in a 351W with a B+M mini blower on it, 8#s of boost. I over reved the motor at the track and broke the ring lands off of all the pistons on the drivers side. All the chunks (about 1 1/2" long each) went out the exhaust. I will never build another performance engine with hypereutectic pistons, they leave for no margine for error.
TurboJunky is offline
post #4 of 8 Old 04-11-2007, 08:02 PM
I'm running 13lbs of boost on hypercrappy pistons, course it's only been a week since it's been upped to that...
scottm93GT is offline
post #5 of 8 Old 04-11-2007, 08:11 PM
As with anything the trick in the tune...but 13psi seems alot to me. I would stick below that 13psi...10psi or so, depending on pulley. I busted a 96 440rwhp cobra with 11-12 psi after a year or so of "having a good time". Different motor all together but still keep it safe if you want this to last long.
65 Mustang
68 Barracuda 440
boostdidfox is offline
post #6 of 8 Old 04-22-2007, 05:38 AM
My stock bottom end 302 H/C/I in my 95 held 12psi with a Vortech S-trim non intercooled with 42 lb inj for 3 years making 508rwhp 489 lb ft tq.it didn't break until the boost was upped to 16psi and made 570rw and noticed under full throttle the oil. press would drop suddenly so when it was taken apart the pistons were perfect but the block was broken in 3 places. The motor had 86,000 on it when I put the blower on it ,It had a Nitrous express kit on it for 2 years prior to that with a 90 shot on it , the car weighed 3420lbs and ran 11.20 at 126 consistantly.....never even blew a gasket....no failures at all , 93 octane splashed with 114 octane 5 spd 3.73 gear and Et streets 28x11.50-15....not the radials.....the hyperuetectics are actually pretty tough , its all in the tune ....50lbs of fuel press at idle 60 under boost , 10deg initial timing
347pace_car is offline
post #7 of 8 Old 04-23-2007, 02:49 PM
quarterstang86's Avatar
Lidio out of Alternative went 9's in his street car (yellow coupe) with a stock lightning shortblock and Vortech boost thru a near stock AODE.
Simple enough - it's all in the correct tune.
quarterstang86 is offline
post #8 of 8 Old 04-27-2007, 11:16 PM
any piston will blow up if detonated against enough, the hypers just go earlier. tune or die.
kingmoochr is offline
