What Radiator Are you Guys Using? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 25 Old 04-09-2007, 08:14 AM Thread Starter
It would appear that the 31X19 Summit universal that I bought is too damn big....it is interfering with some of my turbo piping. It is just a little too wide. The stock radiator will fit which is 2" smaller.
This is with a Cartech street kit on a 90 LX convertible.
Just want to see what everyone else is using. Thanks in advance.
89notch is offline
post #2 of 25 Old 04-09-2007, 09:49 AM
brian15's Avatar
i run a modine stock replacment , mark8 fan and transcooler infront of the radatior with no issues
brian15 is offline
post #3 of 25 Old 04-09-2007, 02:55 PM
rdub79's Avatar
Trader Feedback: (80)
Griffin 31 x 18 1/2 x 2 1/4
Proform 16" elec. fan
I had do do a little massaging with the BFH to get the rad in there though.
B&G hotside kit
Custom coldside
3.5 wide intercooler
A/C too!
88' Coupe
rdub79 is offline
post #4 of 25 Old 04-09-2007, 03:01 PM
97SVT's Avatar
AFCO from Holcomb. Fit pretty good, lower hose was tight to slip over the outlet, made some little "L" brackets to attach the top. 16" electric fan.
Running a B&G kit
1967 Mustang Coupe
1990 Mustang GT Turbod DD
1987 Mustang GT Turbod-9.75 @ 140mph gone but not forgotten
97SVT is offline
post #5 of 25 Old 04-09-2007, 03:13 PM
fred50stang's Avatar
I am using the FRPP alum replacement for foxbody. Fits perfect, and no problems.
fred50stang is offline
post #6 of 25 Old 04-09-2007, 09:28 PM
Blackfive0's Avatar
Trader Feedback: (62)
Be cool radiator with flex-a-lite dual fan
http://store.summitracing.com/partde...5&autoview=sku
Blackfive0 is offline
post #7 of 25 Old 04-10-2007, 01:09 PM
This is the one I always used but when my last one went out, I got me a cheap parts store replacement. No issues with either.
post #8 of 25 Old 04-10-2007, 02:04 PM
millhouse's Avatar
El-cheapo autozone 3-core replacement here too. It cools great with my twin setup (electric fan) even during the summer.
2016 Ruby Red Mustang GT PP
Prior Cars
millhouse is offline
post #9 of 25 Old 04-10-2007, 02:34 PM Thread Starter
Thanks guys...as nice as the aluminum looks I may just go 3 core brass from the parts store. That with my Mark VIII fan should be plenty.
89notch is offline
post #10 of 25 Old 04-10-2007, 09:40 PM
i run the be cool 60165 part #, its a ford universal, but had to do some customizing for the top to hold it in place, and a proform elec fan
sprayed88 is offline
post #11 of 25 Old 04-11-2007, 02:37 AM
Formerly known as 20thAniv
Unatural's Avatar
I'm running the Summit 31 X 19 on my car with the Cartech Street Sleeper and it works fine. My intercooler is a horizontal mount, but I don't think that will make a difference. I'm running a Mark VIII fan too. Can you take pictures of where it isn't clearing so I can take a look at it? If you're talking about down on the radiator core support where the radiator sits, if you just mess with it a little and cut the stock rubber mounts, it will fit.
Wayne
'91 LX Hatch
Single turbo
, KWS Images on FB and IG
https://forums.corral.net/forums/turbochargers/1379238-unaturals-diy-build.html
Unatural is offline
post #12 of 25 Old 04-11-2007, 02:54 AM
1foxbody32's Avatar
Trader Feedback: (26)
jegs universal 31x19
SIRACING.NET
1foxbody32 is offline
post #13 of 25 Old 04-11-2007, 12:19 PM
Steed93's Avatar
I am running a Summit one too. Mine might be the 27" x 19" one though.
1993 LX hatch
11.21 @ 124
480 whp, 520 wtq (10 psi)
Steed93 is offline
post #14 of 25 Old 04-11-2007, 08:21 PM
I have a Griffin. Cheap electric fan I got for $40 at a speed shop in Houston and I have had zero problems cooling my 306 single turbo and now (306 let go) my 351w turbo. I live in texas and even in summer in Austin traffic (which is the worst imho) it has yet to get hot. Matter of fact I have my fan on toggle switch that I only turn on during extreme hot days. Used Griffins are reasonably priced on here. GL
65 Mustang
68 Barracuda 440
boostdidfox is offline
post #15 of 25 Old 04-12-2007, 09:28 AM
Gabe's Avatar
Do those Proform fans work good?
Gabe Davila
93 Lime Green Coupe RIP 11.2 @127 all motor
95 Turbocharged Cobra
90 Titanium coupe
Gabe is offline
post #16 of 25 Old 04-13-2007, 02:08 AM
C&R
Newt-Rod is offline
post #17 of 25 Old 04-13-2007, 08:03 AM
brian15's Avatar
is there a noticable weight difference between the aluminum and brass radatiors ?
brian15 is offline
post #18 of 25 Old 04-13-2007, 10:00 AM
If you are refering to me...because I think my fan is proform, then yeah they seem to move a decent cfm of air. I believe it is rated for 2100 but it has been awhile since I have purchased it so my facts may not be in check.
65 Mustang
68 Barracuda 440
post #19 of 25 Old 04-13-2007, 12:07 PM
Gabe's Avatar
I saw in Jegs for like 120. They say it works just as good as the Black Magic. I might buy one.
Gabe Davila
90 Titanium coupe
Gabe is offline
post #20 of 25 Old 04-13-2007, 12:08 PM
Gabe's Avatar
Did you have to modify alot when using the radiator?
Gabe Davila
90 Titanium coupe
Gabe is offline
post #21 of 25 Old 04-13-2007, 03:30 PM
Unatural's Avatar
No, the only stuff I modified was taking out the rubber mounts at the bottom and top brackets and cutting them a little bit to make them fit.
Wayne
'91 LX Hatch
Single turbo
Unatural is offline
post #22 of 25 Old 04-13-2007, 07:39 PM
Trader Feedback: (22)
I use a Fluiydyne and a new Black Magic S-Fan, works great w/ a Hellion Turbo.
turboLXstang is offline
post #23 of 25 Old 04-14-2007, 09:45 AM
Gabe's Avatar
How much was the radiator?
Gabe Davila
90 Titanium coupe
Gabe is offline
post #24 of 25 Old 04-14-2007, 10:49 PM
Unatural's Avatar
I don't remember. It was the Summit brand 31X19 universal one. Be warned that the fittings on it where the radiator hoses attach are bigger than stock and it can take a little persuasion to get the hoses to fit right. Also, if you're running a Cartch turbo kit with the PS relocator bracket, you'll need to buy a universal style radiator hose from the parts store for the lower hose. I can't remember how long it needs to be, but it's pretty easy to figure out once you have everything mounted.
One thing I don't like about the radiator is that the lower fitting on the radiator comes out at an angle instead of being straight like a stock one. It can be fixed by just cutting it off and rewelding it, I just haven't done it.
Wayne
'91 LX Hatch
Single turbo
Unatural is offline
post #25 of 25 Old 04-15-2007, 01:33 AM
/\/otchback92's Avatar
be cool with flex-o-lite fan. Custom mounting tabs.
/\/otchback92 is offline
