autolite 3923 or 3924 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 04-06-2007, 09:48 AM Thread Starter
brian15's Avatar
stock shortblock
performer heads with 1.9 valve
crower 15511 cam w/1.6 rockers
performer rpm2 intake
hellion 62mm turbo kit on 11psi
stock ignition , good wires and cap
would you run a/r 3924's or a/r 3923's on a set up like this and why ?
brian15 is offline
post #2 of 10 Old 04-06-2007, 09:53 AM
With alum. heads and power adder run the autolite 3922's
TFScoupe is offline
post #3 of 10 Old 04-06-2007, 10:18 AM Thread Starter
brian15's Avatar
got ya .... any reason behind that ? 3922 are 2 steps colder correct ?
brian15 is offline
post #4 of 10 Old 04-06-2007, 12:30 PM
Yeah, 1 range colder with the alum heads and an additional range colder for the boost......
TFScoupe is offline
post #5 of 10 Old 04-06-2007, 02:11 PM
Trader Feedback: (22)
I bought a used set ow TW Heads and called Trick Flow and asked what plug they recommended and they said 3924, so I went w/ a 3923, would that be a problem? Car is about 5 days from running.
turboLXstang is offline
post #6 of 10 Old 04-06-2007, 02:31 PM
staticstang's Avatar
I run 3923's on my TW Heads. Haven't had the car under a full load of boost, but it has seen many bottles of nitrous and the 3923's. Trick flow recommends the 3924's as a stock style plug for the TW cylinder heads, when adding boost/nitrous i would recommend going w/ the 3923's. Don't go any colder than what you have too. Same goes for plug gap, the wider the gap the better the potential to ignite the fuel mixture, only go as tight as needed.
staticstang is offline
post #7 of 10 Old 04-06-2007, 05:14 PM
cobra29svt's Avatar
Trader Feedback: (15)
3923's
95 cobra 90 gt
hp turbo kit black-on-black
systemax heads and intake
stupid little bolt-on's
cobra29svt is offline
post #8 of 10 Old 04-06-2007, 05:26 PM
1995gtCPE's Avatar
Trader Feedback: (34)
3923
1995gtCPE is offline
post #9 of 10 Old 04-06-2007, 07:31 PM
Blackfive0's Avatar
Trader Feedback: (62)
I could be wrong but aren't 3922 3 heat ranges colder.
Anyway I ran 3923 gaped @ .027 one both my performer and my Track heat heads.
Blackfive0 is offline
post #10 of 10 Old 04-06-2007, 08:31 PM
yes correct 3925 s are stock, 24 s are 1 step colder 23 s are 2 steps colder
sprayed88 is offline
