cartech turbo kits - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 64 Old 03-25-2007, 08:54 PM Thread Starter
Gabe's Avatar
cartech turbo kits
Anyone run a cartech turbo kit?
Gabe Davila
93 Lime Green Coupe RIP 11.2 @127 all motor
95 Turbocharged Cobra
90 Titanium coupe
Gabe is offline
post #2 of 64 Old 03-26-2007, 11:56 AM
I ran one a long time ago and still randomly buy things through them. I remember reading awhile back they were working on doing a twin street kit for fox bodies. The only kit that was all that great that they sold was probably their SN95 Outlaw kit. The other ones are just so outdated and much better options can be had these days.
post #3 of 64 Old 03-26-2007, 10:38 PM Thread Starter
Gabe's Avatar
I just bought the outlaw kit but for fox body.
Gabe Davila
90 Titanium coupe
Gabe is offline
post #4 of 64 Old 03-27-2007, 12:44 AM
HuebyStang's Avatar
Trader Feedback: (34)
I run one...... it's dated and a hassle to work with sometimes, but it works....
Current: 1994 Cobra - 200k+ miles, mostly stock
Previous: 1994 GT - Built 347 with boost
HuebyStang is offline
post #5 of 64 Old 03-27-2007, 12:08 PM
Singleturbostang's Avatar
Me too. changing the driver's side plugs is kinda a bitch on my street sleeper kit, but it works......I'm running low 10's with it.
'78 Fairmont Boxtop.... Once over lightly. Under re-construction
Singleturbostang is offline
post #6 of 64 Old 03-27-2007, 06:31 PM Thread Starter
Gabe's Avatar
what size turbo do you have and injectors are you running.
Gabe Davila
90 Titanium coupe
Gabe is offline
post #7 of 64 Old 03-27-2007, 06:33 PM Thread Starter
Gabe's Avatar
HuebyStang, what times are you running?
Gabe Davila
90 Titanium coupe
Gabe is offline
post #8 of 64 Old 03-27-2007, 08:11 PM
HuebyStang's Avatar
I'm running 42# injectors.... T64e turbo.... I honestly do not have any times at the moment with this setup. I haven't had it up long enough and the season is just coming back (Midwest weather).
post #9 of 64 Old 03-27-2007, 09:36 PM Thread Starter
Gabe's Avatar
what about dyno numbers?
Gabe Davila
90 Titanium coupe
Gabe is offline
post #10 of 64 Old 03-28-2007, 12:36 AM
I run one with a T67, the sn95 outlaw kit that is. I am finishing up my project but it works perfect and is very nice.
Had to sell my prized 1994 Turbocharged GT. Downgraded to a turbo diesel VW Jetta 5spd. I still have my motorcycle to go fast though!
locouno5.0 is offline
post #11 of 64 Old 03-28-2007, 05:49 PM Thread Starter
Gabe's Avatar
do you have pic's
Gabe Davila
90 Titanium coupe
Gabe is offline
post #12 of 64 Old 03-29-2007, 12:40 AM
I can't seem to be able to add an image to the post. I click the insert image icon and it wante me to enter an url. If you send me your email or email me then I can send you some pictures. Just tell me what you want pictures of as I took photos from every step of my build, even the tiniest of details. Thanks.
Travis
[email protected]
post #13 of 64 Old 03-30-2007, 03:21 PM
xlr8a4d's Avatar
It can't be worse than changing them on a Incon equipped Mustang,lol.
1992 LX coupe-Incon twin turbos
1983 GT Widebody
1988 BroncoII-5.0/AOD transplant
xlr8a4d is offline
post #14 of 64 Old 04-02-2007, 12:02 AM
Gabe!!..clean out yer p/m's so i can reply to you !!...lol...
1995 5-Speed GTS
San Antonio, Texas
Vortech Race V-1, Custom frt mount Air/Air intercooler setup W/ 3" piping, 4" Power Pipe, AFR heads, 1.7rr's, BBK SSI intake ,75mm T/B, 1 5/8 shorties, h-pipe, flows, 3.73's, 42lb inj, 80mm MAF, 255LPH in-tank pump, tuned by Mike Murillo
txlen is offline
post #15 of 64 Old 04-02-2007, 09:04 PM Thread Starter
Gabe's Avatar
Done.
Gabe Davila
90 Titanium coupe
Gabe is offline
post #16 of 64 Old 04-02-2007, 09:47 PM
Gabe..what turbo did ya go with??...T-4 ??....T-6?? what A/R ????
1995 5-Speed GTS
San Antonio, Texas
txlen is offline
post #17 of 64 Old 04-06-2007, 08:20 PM
I ran a Cartech Outlaw kit on my 87 GT.. I modified it to fit a 351 size motor.. And I modified it to use a PT88 turbo, instead of the T76 that came in the kit..
One of the things I like about the Cartech kit, especially when modifying it, is that it puts the turbo right near the front mounted intercoolers intake.. So piping it is pretty easy..
It ran pretty good like that, as you can see in my signature.. And that was on unleaded gas, with my undersized Cartech wastegate screw turned all the way out.. And full manifold pressure going to the bottom of it's diaphram..
I'm next going to modify the kit to run with a front motor plate, and a T6 turbine housing.. The flange on my drivers side header than now has the cross over pipe connected to it.. Is going to be where I pipe my new 60mm wastegate from.. And I going to make a Y connection with the current crossover pipe into a T6 flange..
With a bigger cam..Ported heads.. And the T6 turbine housing with a 5 inch downpipe (up from the current 4 incher).. I just might be able to get some 8.6's from this setup..
Bellman Jeff is offline
post #18 of 64 Old 04-06-2007, 11:08 PM
One thing that sucks about the street Cartech kit for Fox body kits is that you have to do a couple of 90 degree turns to get from the turbo outlet into the intercooler inlet.
post #19 of 64 Old 04-11-2007, 08:55 AM
Not to hi-jack the thread but people say the kit is outdated and what not but if I wanted to run consistent 10's with the fox body SS kit would it still be ok for that?
jeffholio is offline
post #20 of 64 Old 04-11-2007, 02:28 PM
It can be done and has been done but the problem is depending how much boost you have to run to get there you might run into back pressure issues and be constantly fighting things to stay sealed and what not. I'd use something else if I wanted to run 10s.
post #21 of 64 Old 04-11-2007, 07:48 PM Thread Starter
Gabe's Avatar
From what I hear It's preety easy to run ten's with the ss kit. There is a few guys running stock 302's with a/c running low 11's with drag radials and high tens with slick's. with power steering and air conditioning. Not too many kits factory accessories from what I hear. My kit will be on my car hopefully this month. i will let you know, what I think.
Gabe Davila
90 Titanium coupe
Gabe is offline
post #22 of 64 Old 04-11-2007, 10:05 PM
TTI and Turbotime will let you keep all factory accessories like the Cartech SS lets you do. Turbotime looks to be light years ahead in design and it seems to be loosely based on the old T/E kits that have not been made in like a decade now. Look at Trent's old GT for an example of the troubles related to a Cartech SS kit and trying to run in the 10s. There are then a ton of other kits that let you keep all accessories but the smog pump.
post #23 of 64 Old 04-12-2007, 09:07 AM Thread Starter
Gabe's Avatar
Since you live in Houston is there anybody that is a good tunner?
Gabe Davila
90 Titanium coupe
Gabe is offline
post #24 of 64 Old 04-12-2007, 10:53 AM
I use Murillo out of San Antonio, never had a bad experience with him so never had the need to try and find someone else.
post #25 of 64 Old 04-12-2007, 11:51 AM Thread Starter
Gabe's Avatar
That's cool, I use him too. We are actually friends, but I was just wondering who was tunning in the Houston area. Is Joe Riveria still around
Gabe Davila
90 Titanium coupe
Gabe is offline
post #26 of 64 Old 04-12-2007, 11:57 AM
I hear rumors about Joe every once in awhile but I think for the most part he is not working on modified cars much at all.
post #27 of 64 Old 04-12-2007, 12:15 PM Thread Starter
Gabe's Avatar
I talked to him about 8 years ago and he said that he wanted to do something else. That was the las time I heard from him.
Gabe Davila
90 Titanium coupe
Gabe is offline
post #28 of 64 Old 04-12-2007, 12:16 PM Thread Starter
Gabe's Avatar
Does Steve Dryer still ahve his shop open?
Gabe Davila
90 Titanium coupe
Gabe is offline
post #29 of 64 Old 04-12-2007, 12:25 PM
I have no idea on Steve, actually the name only rings a bell in my head and I can not even place it with a face any more. I do not keep up with many of the shops down here. I used to deal with MTI but that was only because a friend was the shop manager there. Prior to that and this dates back a long time, I dealt with Texas Turbo a lot which is how I originally met Joe.
post #30 of 64 Old 04-13-2007, 12:05 PM Thread Starter
Gabe's Avatar
He use to own Houston Performance.
Gabe Davila
90 Titanium coupe
Gabe is offline
post #31 of 64 Old 04-17-2007, 03:34 PM
I have the Cartech Outlaw kit , other than the cracking header I like it I am gonna have Rigid Race Cars build me a new turbo header and buy a new Wastegate and BOV but I like it all and all ....
buhbyy is offline
post #32 of 64 Old 12-02-2007, 10:13 PM
pkstang's Avatar
Trader Feedback: (161)
hi jeff
i sent you a PM the other day hoping you could share just what exactly was required to get that cartech outlaw kit to work on your 351w... i know the crossover has to be modded but was there anything else? how did the headers fit?
any info will be greatly appreciated
thanks jeff
paul k
ps... do you have any other pics of your setup that you could post or email me ([email protected])?
pkstang is offline
post #33 of 64 Old 12-12-2007, 03:14 PM
stangman88's Avatar
You only have to add a few inches to the cross over pipe for the kit to work on a 351 w.
I have the cartec outlaw kit with a t-76 gtq trim. On a 306 stock crank and rods and stock e-7's on 25 psi i went 9.92 @138 on dragradials. So call them outdated if you will but they do work.
stangman88 is offline
post #34 of 64 Old 12-12-2007, 03:19 PM
I thought Jeff had to do more than just extend the crossover pipe or was that because he ran a PT88 that he had to do more?
As far as my outdated comment, never said they do not make power. The newer options out there let you make the power and retain more things on the car.
post #35 of 64 Old 12-15-2007, 12:47 PM
pkstang's Avatar
that's awesome stangman... what block are running and have you dynoed the car?
pkstang is offline
