Here's a few pics of the engine - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 14 Old 03-24-2007, 12:50 PM Thread Starter
Its still not all cleaned up... as you can see I still need to hide a few vac lines, and get a turbo blanket
Any recommendations on a blanket?
Went for a wot run yesterday, and total timing was only about 14 degrees.... so theres a lot of power left in it, just gotta tweak it a little.
The drag strip opens in 3 weeks.... hoping for mid to low 11's
Will
Teal94GT50 is offline
post #2 of 14 Old 03-24-2007, 12:57 PM Thread Starter
post #3 of 14 Old 03-24-2007, 03:44 PM
Nice! Looks sweet
oldbugs is offline
post #4 of 14 Old 03-24-2007, 04:24 PM
looks way better than mine.
I have a blanket from vs racing.
http://www.turbomustangs.com/smf/ind...?topic=75173.0
My fender used to get so hot I could not touch it. Now you can touch it, and the blanket.
1994 Turbo GT
mustangless is offline
post #5 of 14 Old 03-25-2007, 05:52 PM
Gabe's Avatar
Nice. did you dyno it yet?
Gabe Davila
93 Lime Green Coupe RIP 11.2 @127 all motor
95 Turbocharged Cobra
90 Titanium coupe
Gabe is offline
post #6 of 14 Old 03-25-2007, 06:55 PM
Looks real nice, good work!
92SilverStang is offline
post #7 of 14 Old 03-27-2007, 06:28 PM Thread Starter
Nope, no dyno time yet. I don't really live anywhere close to that I know of that has a dyno. I'll run it at the drag strip in a few weeks.
Thanks for the website for the blanket. I hear ya on the heat. Everything gets waaaaaaaay to hot to touch. Especially the intake pipe above the turbo. It gets hot enough to burn my finger. I'm sure the blanket will help brings temps down all around.
Thanks for the compliments!!
post #8 of 14 Old 03-27-2007, 09:38 PM
Gabe's Avatar
I had a kit just like it last year. I put 480 torque to the rear wheels. FUN for a stock Cobra with 42 lb injectors.
Gabe Davila
90 Titanium coupe
Gabe is offline
post #9 of 14 Old 03-28-2007, 12:39 PM
Erich's Avatar
Looks great!
Erich
Erich is offline
post #10 of 14 Old 03-28-2007, 07:19 PM
1995gtCPE's Avatar
Trader Feedback: (34)
You fuel feed line is right on the downpipe.
1995gtCPE is offline
post #11 of 14 Old 03-30-2007, 11:45 AM
my intake pipe gets hot too, but it is also sitting on top of the downpipe. I am working on redoing it now so maybe it won't touch.
1994 Turbo GT
post #12 of 14 Old 03-30-2007, 03:38 PM Thread Starter
The fuel line is nowhere near touching the downpipe. It is close the the wastegate pipe though, but that's why i wrapped it w/ 2000 degree wrap. That stuff works great. I also have part of the lower rad hose wrapped in it.
I have quite a bit left over, so I think im going to wrap the intake pipe with it next. It really does repel the heat like it says it does.
Mustangless, that might be something to look into on using on your intake pipe if you want a cheap fix.
Will
post #13 of 14 Old 04-01-2007, 10:55 PM
hey great job will. guys i have road in this car and it is very quick. low 11's is very realistic. this car is super clean. will done a great job. congrats on the civic.
gearhead93gt is offline
post #14 of 14 Old 04-02-2007, 07:52 AM
xr8240's Avatar
Nice engine bay.. Tempts me to paint my inlet...
I like shields rather than blankets, some nice polished stainless steel shields looks bling bling....Doesn't hold heat in turbine as much either when engine isturned off...
xr8240 is offline
