blow thu questions related to maf - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 03-22-2007, 05:51 PM Thread Starter
how many inches do i need after my maf, of straight pipe, ive got about 12 inches in front with my bov in the middle, the reason i ask is because right after my 3 " pmas i have a 90 silicon that hooks in the fender and goes to the tb, is this going to be a problem thanks, it is a blow thru
sprayed88 is offline
post #2 of 6 Old 03-23-2007, 10:23 AM
awdgsx's Avatar
Nothing after the maf matters, Only what's in front of it.
PMAS- owner
Flowing freely while getting things flowing.
Eaton Rapids, MI
awdgsx is offline
post #3 of 6 Old 03-23-2007, 01:31 PM
Not entirely true. You need some space between the MAF and the throttle body so you don't encounter backwash on shifts or when the throttle is closed suddenly, though the area in front of the MAF is more important for smooth flow on acceleration.
On my TTv6, I've got about 9" in front of the MAF, and 4" behind the MAF of straight pipe - and it reads pretty smooth My first turbo kit had much less optimal pipe routing, and it sampled like crap.
~Brad
2000 v6. The not-so-daily-driver daily driver - 2x T3/T40B Hybrids. 2x Tial 38mm Wastegates. HKS SSQV BOV. Massive FMIC.
Come out and play - 370hp/395ft-lbs at wheels. It's just a six, right?
piratius is offline
post #4 of 6 Old 03-25-2007, 11:37 PM Thread Starter
COOL THANKS I GOT AT LEAST 12
post #5 of 6 Old 03-25-2007, 11:39 PM Thread Starter
cool i also run the ssbov hks and tial 38 mm wg
post #6 of 6 Old 03-25-2007, 11:41 PM Thread Starter
