Setting up a Demon for blowthrough - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 03-20-2007, 08:49 PM Thread Starter
WICKED87COUPE's Avatar
Need any help ,tips,advise I have a 650 mighty demon for my latest blow through carb project and need help setting it up.
1974 Maverick5.0/AOD driver swap
1990 F150bone stock
1992 cavalierRice Killa....
WICKED87COUPE is offline
post #2 of 13 Old 03-20-2007, 09:21 PM
is it a blow-through?
holdmeback is offline
post #3 of 13 Old 03-20-2007, 09:26 PM
and where the hell is ooltewah
post #4 of 13 Old 03-20-2007, 10:23 PM Thread Starter
No it will need to be converted (wich is what im asking about)
1990 F150bone stock
post #5 of 13 Old 03-20-2007, 10:23 PM Thread Starter
In between chattanooga and cleveland
1990 F150bone stock
post #6 of 13 Old 03-20-2007, 10:41 PM
i have a mighty demon 750 blow-through is why i am asking and there are alot of things different about them such as type of floats, pvcr, you would have to remove the choke horn it will have to be a mechanical secondary carb also. blow-throughs are kinda hard to tune also.
post #7 of 13 Old 03-20-2007, 11:08 PM Thread Starter
I have been looking at there new blow through carbs, I figured since i had this one it would be easier and cheaper to convert I used to have a link bookmarked that gave the run down of modifications but have seem to have lost it and cant find it via google or searching.
1990 F150bone stock
post #8 of 13 Old 03-20-2007, 11:14 PM
you can go to www.turbomustangs.com and check out the blow-through section and you will find what you are looking for. and yes it will be cheaper but i dont know about easier.
post #9 of 13 Old 03-20-2007, 11:17 PM Thread Starter
Thanks for the link. I hope this little project works out
1990 F150bone stock
post #10 of 13 Old 03-20-2007, 11:20 PM
i spent 8 hours on a dyno to get mine right with a carb that was already set-up for blowthrough if that tells you anything
post #11 of 13 Old 03-20-2007, 11:22 PM
i myself am going to a csu carb because im looking for a little more carb so if your interested i will be selling mine soon
post #12 of 13 Old 03-20-2007, 11:51 PM Thread Starter
I figured id have to spend alot of tuning time on it.
1990 F150bone stock
post #13 of 13 Old 03-21-2007, 04:27 PM
Stang Seller's Avatar
Trader Feedback: (26)
Do a search under my username on Turbomustangs.... I asked the same question about the blow through Demon carbs and everyone seems to say neigh. They all say to spend a little more money and getting a good built CSU carb. It's a $300+ difference between the two new, but everyone swears by the CSU units and I have heard NOTHING but positive raves about them.
SS
'86 GT T-Top - 5.0/T5 - in pieces.
'90 LX Vert - stock
'83 Cutlass Cruiser LS/LR4 swapped, TH350, 8.8 rear swap
Stang Seller is offline
