At What Boost Level Is Aftermarket Iginiton Required? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 03-20-2007, 04:18 PM Thread Starter
I realize this will probably be different on every car, but I am just trying to get an idea. Does anyone here get by with their stock ignition without any problems and if so, how much boost and power are you making?
I will be running between 7-9 psi on a mild 302 (GT-40 Aluminum heads, Cobra Intake, Stock Cam w/ 1.7 RR) is the basic combo, Cartech Street kit with a T-64.
It is probably 75% complete...but I did not invest in an aftermarket ignition...will this likely be a problem?
Thanks in advance.
Dan
89notch is offline
post #2 of 4 Old 03-20-2007, 06:57 PM
i think the stock ignition will be fine, the only concern i have is you will have to lower the gap on your plugs and im not sure how low the gap before your stock ignition wont fire the plugs my gap is at .30 but i have MSD
holdmeback is offline
post #3 of 4 Old 03-20-2007, 09:46 PM
brian15's Avatar
.25 gaps here ....stock coil , distributor
fms wires , msd cap and thats it no problems as of now
msd ignition on list of do things
brian15 is offline
post #4 of 4 Old 03-22-2007, 10:03 AM Thread Starter
Looks like I can try to stick with stock for now and make sure my gaps are good...if I have blow out then I will upgrade...thanks guys.
Dan
89notch is offline
