HP turbo almost done - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 03-19-2007, 05:36 PM Thread Starter
fred50stang's Avatar
Smile HP turbo almost done
I just figured out how to post pics. So here are some pictures of my HP turbo project. Its the stage II. I can say that I did get everything, and all piping fit perfect! I did not get any directions what-so-ever. I have the car ready to start, however I have to talk to somebody about the mass air stuff.
List of things....331 forged rotating assy(done locally by Speed Unlimited), Comp custom grind turbo cam, Windsor Sr. Alum heads(ported), tfs-r intake, and stock fuel lines and 42#'rs for now I just wanna get it running. Its been 7 years!! The trans is a Astro performance G-force bought through www.artsperformanceparts.com as well as a bunch of other things. Great guy to deal with btw!! I have a slew of other parts, if you wanna know what I got just ask, I am not trying to hide anything.
Here are the pictures.
fred50stang is offline
post #2 of 13 Old 03-19-2007, 05:38 PM
Looks awsome should put down some good numbers! what size turbo is it?
1991 mustang LX coupe
1993 mustang lx black/black
blachatch is offline
post #3 of 13 Old 03-19-2007, 06:38 PM
blk91coupe's Avatar
Prob the 66mm if its the stage 2. Should run great. Looks good man.
blk91coupe is offline
post #4 of 13 Old 03-19-2007, 06:56 PM Thread Starter
Yup a 66mm.
It probly wont make but 500hp b/c I am limited by my fuel system.
post #5 of 13 Old 03-19-2007, 07:09 PM
Nice BRO!
stangss is offline
post #6 of 13 Old 03-19-2007, 08:13 PM
blk91coupe's Avatar
Originally Posted by fred50stang View Post
Yup a 66mm.
You will still have a bad ride. Last Sat at our local track a stock shortblock car was there with the stage 1 hp kit with a small comp cam, tfs heads and a performer rpm and he said it was making 586rwhp with stock fuel system. Tko 600 with 3.27s and he was blowing off the 26/10 et drags in 2nd. It went 6.7s at 107 though. He said he bought it used off here.
post #7 of 13 Old 03-19-2007, 10:16 PM
Blackfive0's Avatar
Trader Feedback: (62)
I had the stage 1 kit one a 331, mods are in sig. I made 500rwhp and 606 ft lbs on only 9 psi and a stock fuel sytem. Could have made more but was have a problem getting my mass air to stay on the piping under boost.
Blackfive0 is offline
post #8 of 13 Old 03-19-2007, 11:50 PM
Does the drain have a slight uphill to it?
mustanggreg is offline
post #9 of 13 Old 03-20-2007, 12:26 AM
cobra29svt's Avatar
Trader Feedback: (15)
looks great!
95 cobra 90 gt
hp turbo kit black-on-black
systemax heads and intake
stupid little bolt-on's
cobra29svt is offline
post #10 of 13 Old 03-24-2007, 06:16 AM
monstang's Avatar
Trader Feedback: (26)
thanks for the pics. i will be looking forward to more pics running and all.
A guy came over and started talking to me about the car. He asked what it ran so I told him 8.80's. He said, "No, I meant in the 1/4 mile."
NOVI357
monstang is offline
post #11 of 13 Old 03-24-2007, 01:44 PM
TurboJunky's Avatar
Yes, well at least mine did. I cut mine and made it shorter so that it did not have that droop in it.
TurboJunky is offline
post #12 of 13 Old 03-24-2007, 06:17 PM Thread Starter
Ditto. That pic was taken upon first assembly. I have since shortened the hose, about 5in. and no more droop. And the upper rad. hose is not touching the "hot side" exhaust, I have about 2in of clearence. The angle of the pic makes it look like it touches.
post #13 of 13 Old 03-25-2007, 12:26 PM
GTmustang00's Avatar
are you happy with the kit? any install issues? im going to order the gt42r or the t88. we shall see.
98 Chrome Yellow cobra 9800 miles
1989 Mustang GT, modified to hell
GTmustang00 is offline
