air filter restriction? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 03-12-2007, 04:49 PM Thread Starter
I have a 90* silicone elbow going from the front of the turbo to inside the fender. The silicone elbow goes from 4-3.5". I have the kn filter that is made for 94-95 5.0 mustangs on the end of the elbow. It measures
Base Inside Diameter: 3.25
Height: 7.375
Top Outside Diameter: 3
http://www.knfilters.com/search/prod...px?Prod=E-0940
Is the elbow hurting me going from 4-3.5? If not, do I need a bigger filter such as this
http://www.knfilters.com/search/prod...x?Prod=RE-0920
Base Outside Diameter: 6 in
Height: 9 in
Top Outside Diameter: 4.625 in
This is on a 60mm turbo
1994 Turbo GT
mustangless is offline
post #2 of 6 Old 03-13-2007, 08:21 PM
why not just do like everyone else does and install your filter directly to the turbo? and yes it will at least rob 1 # of boost
holdmeback is offline
post #3 of 6 Old 03-13-2007, 10:15 PM Thread Starter
I do not have enough room
barley got the turbo in there.
1994 Turbo GT
post #4 of 6 Old 03-13-2007, 10:41 PM
cobras281's Avatar
just put screen on it... do a search over at turbomustangs I think there is a GB for some
cobras281 is offline
post #5 of 6 Old 04-03-2007, 05:46 PM
The air cleaner will not hurt you. If you use a screen rather than a filter I hope you enjoy replacing the compressor wheel and housing every season.
"Britney spears doesn't sing. She makes vocal noises into a microphone. There is a top-notch engineer who then feeds that signal through an alchemist's collection of signal processing tools and renders something that millions of fans with no taste will buy."
got boost? is offline
post #6 of 6 Old 04-04-2007, 07:20 PM
They do make these little small foam filters that look similar to a flattened mushroom. My buddy that has a 800hp supra runs one. Not entirely sure of how the restriction is but seems to work for the import crowd. I would research it further.
65 Mustang
68 Barracuda 440
boostdidfox is offline
