Garret T3 question...help me out - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 03-07-2007, 11:22 PM Thread Starter
TattooedScumbag's Avatar
I have a pair of T3's .48/.63s I believe...The exhaust housing on one of them has a small hairline crack around the hole where I think the wastegate hooks up..the smaller hole beside where the exhaust is. Is this fixable? I would like to get it fixed so I can sell them or would the housing need to be replaced..if so I will just sale as is and let the new owner do with them as he/she pleases..Thanks a lot
No more Mustangs...ever...well a new project might be brewing
01 Explorer Sport Trac(I hate this thing with the fire of 1000 hells)
TattooedScumbag is offline
post #2 of 6 Old 03-08-2007, 12:21 AM
Scones's Avatar
if you find one that doesn't have a couple hairline cracks around the hole you're lucky, most do and it doesn't make a difference. is there any shaft play in these?
1986 5.0TT Tribute Car
2010 Ranger 4.0
1989 Kawasaki Ninja ZX6
Scones is offline
post #3 of 6 Old 03-08-2007, 08:37 AM Thread Starter
I can move the shaft a little but not a whole lot...whats it take to rebuild them? Im gonna put them up for sale if i can but I will just sell them low enough so that the buyer can get them fixed or whatever..
post #4 of 6 Old 03-08-2007, 11:09 AM
millhouse's Avatar
A small amount of radial play is normal as long as it's not so much that the wheel's contact the housing. It's the axial play that you need to look for...there should be none.
As far as rebuilding goes, they are not to tough to do and the kit's go for less than $100 on e-bay. You should however get them re-balanced after tearing them apart as you can tear through the bearings pretty quick if it's out of spec at all.
2016 Ruby Red Mustang GT PP
Prior Cars
millhouse is offline
post #5 of 6 Old 03-08-2007, 11:32 AM
Scones's Avatar
do they still have their actuators? PM me with a price. i may be interested in having a couple cores around
2010 Ranger 4.0
Scones is offline
post #6 of 6 Old 03-09-2007, 05:31 PM
I was told that if the wheels never contacted the housings at all you should be good to go. Just mark the compressor shaft and install the nut exactly at the same spot.
mustanggreg is offline
