mod or pushrod? help! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 02-26-2007, 04:40 PM Thread Starter
neverbdone93's Avatar
well im wanting to build a new combo but i cant make up my mind which way i want to go. i have a 97 cobra engine with good internals (manley h beam rod and 03cobra pistons)that i could use with my precision 88mm turbo or do i want to sale that and do a 351 base r block engine? if i keep the 4 valve i would want to have the heads and intake ported so for what that would cost i could buy a good set of heads for a windsor. i will need to buy the cams for my 4 valve also so there is another big chunk of money. the car is not a race car. its a 93 gt weekend cruiser/show car/street racer but im looking for around 1000rwhp through a 5 speed the cheapest way possible. just need a little advice from some people who have been there before and know what to expect out of each of these combos (power difference between the two) . by the way the windsor i would build would be somehwere in the neighborhood of 400 cubes with afr 225 (and a really good bottom end of course ) if that helps. like i said not trying to set any records just want another really fast street car. any imput you all could give me would be greatly appreciated. thanks guys
neverbdone93 is offline
post #2 of 13 Old 02-26-2007, 08:46 PM
I personally would stick with the 4v but might just be because been wanting to do a mod turbo car for awhile now.
post #3 of 13 Old 02-27-2007, 06:25 AM
Erich's Avatar
Mod 4V. Sounds like you have that motor in good shape for a turbo-also lighter and much more interesting. Can you just use the stock cams on that?
Erich
Erich is offline
post #4 of 13 Old 02-27-2007, 08:47 AM
FAST
CHEAP
RELIABLE
pick two...
Clevor finished!! Now on to everything else...
phate is offline
post #5 of 13 Old 02-27-2007, 10:24 AM
DNA
Big question
If you don't have all the Mod Motor parts you need now (Sensors, brackets, accy, timing covers, cam covers, etc.....) I would sell your Mod stuff and go Windsor. I have done both types of motors(Windsor/Blower combo and Mod/ Blower and Turbo Combo) and I have found that the Windsor is a bit easier and makes mad power.
The Mod motor is also good at making power but tends to be a pain in the arse when gathering missing parts. ( Doing it riught now with a 2Valve Turbo GT).
Either way you choose do it with the best parts you can afford up front and you will be happy.
DNA is offline
post #6 of 13 Old 02-27-2007, 10:55 AM
ARCANGL's Avatar
Trader Feedback: (76)
I say stay modular... first because its a fox-body at it will be way cool to pop the hood and see a 4-valve
The 4-valve will make plenty of power, so i wouldnt worry about that. I know of 3 cobras around here that put down over 800rw on a single 76mm at only 20psi.
They were 03 cobras, and the only thing they changed in the block was the rodbolts, changing them to ARP2000's, and headstuds, also ARP. They were breathing through stock, unported heads and stock 03 Cobra cams.
ARCANGL is offline
post #7 of 13 Old 02-27-2007, 03:00 PM Thread Starter
Originally Posted by phate View Post
FAST
CHEAP
RELIABLE
pick two...
yeah i meant as cheap as possible. im not gonna cheap out on this either way i go im gonna do it right. i just didnt know if i could do the windsor cheaper or the mod motor
post #8 of 13 Old 02-28-2007, 09:55 AM
DNA
Cost estimates
If you are familiar with it use excell spreadsheets. Lay out all the known costs for each engine, item by item. Then toatal them up and add a 45% of the total as misc to each and see where your costs come out. Contact people like Newtrod etc..
DNA is offline
post #9 of 13 Old 03-02-2007, 07:39 PM Thread Starter
thanks to everybody for responding!
post #10 of 13 Old 03-04-2007, 05:57 PM
TurboJunky's Avatar
I don't know this from personal experiance but from the reading I have done it seems like the modular blocks are very strong in stock form, much more so than a production push rod block.
You already have the mod motor with good guts I would go that way. Plus like it was said before 4 valve mod motor in a fox is a really cool idea.
TurboJunky is offline
post #11 of 13 Old 03-07-2007, 08:28 AM Thread Starter
thanks dude thats probally what im gonna do
post #12 of 13 Old 03-07-2007, 10:48 AM
U.S. Air Force RETIRED
Matt Grieve's Avatar
Trader Feedback: (88)
modular for this reason
http://www.youtube.com/watch?v=eZTPbj19SLs
1990 Mustang GT
2004 Mystichrome Cobra
2015 Mustang Ecoboost
2015 RAM 2500 Cummins
Matt Grieve is offline
post #13 of 13 Old 03-07-2007, 02:37 PM
thats quite impressive, got any more details on them?
aggiez28 is offline
