Turbo build up - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 51 Old 02-25-2007, 09:33 PM Thread Starter
/\/otchback92's Avatar
Turbo build up
Heres a link to my turbo build up. I couldn't figure out how to post pics here.
It's a DSS 306, AFR 185, stock cam, 60-1 turbo, exc. Looking for 450rwhp.
http://www.clubprotege.com/forum/showthread.php?t=26116
/\/otchback92 is offline
post #2 of 51 Old 02-25-2007, 09:52 PM
ratedz's Avatar
Is that a Treadstone/Vecco single hot kit with the 4 bolt on-center mount?
Looks very clean, how far along are you?
1986 Mustang GT
525hp/626tq
ratedz is offline
post #3 of 51 Old 02-25-2007, 11:04 PM
x2 looks like my Vecco kit, clean as hell though! Thumbs up on the clean car! But 450rwhp is going to be easy out of that setup....im shooting for 475rwhp in the next week when i raise my boost to 12lbs with a 63-1 and gt40 heads cobra intake and stock cam
04 Mach 1 Unported Eaton Swap Stock Pulley 478 rwhp
[email protected]
turbo92notch is offline
post #4 of 51 Old 02-25-2007, 11:16 PM
Getnmyfivoh's Avatar
Trader Feedback: (29)
Clean coupe.
Doing a Turbo build up myself for my brother in laws 93GT.
how did you get aerom reg mounted ?
03 Cobra DSG
86/91 MODFOX Mustang Coupe Stormtrooper
www.stangracingproductions.com
Getnmyfivoh is offline
post #5 of 51 Old 02-26-2007, 12:18 AM
1foxbody32's Avatar
Trader Feedback: (26)
Originally Posted by Getnmyfivoh View Post
Clean coupe.
Im wondering the same thing and how you got all your fuel lines ran from the tank to the reg then to the rail and did you do a return??
1foxbody32 is offline
post #6 of 51 Old 02-26-2007, 12:22 AM
rob
rob's Avatar
Trader Feedback: (23)
very nice! goodluck
rob is offline
post #7 of 51 Old 02-26-2007, 07:21 AM Thread Starter
Clean coupe.
Thanks guys! I made an aluim bracket and mounted the reg off the water pump.
I ran 8an out of the tank up along the driver side then I split it behide the engine to feed both fuel rails. then from the rails to the reg and then a 6an return back to the tank.
Yes its the vecco hot side.
post #8 of 51 Old 02-27-2007, 06:33 AM
Erich's Avatar
Here ya go.
Erich
Erich is offline
post #9 of 51 Old 03-01-2007, 04:04 PM
CMcCarthy's Avatar
An extremely nice setup you have there, my man. Good work.
Charles
1992 Oxford White Mustang LX
1984 Oxford White Mustang LX
CMcCarthy is offline
post #10 of 51 Old 03-01-2007, 05:49 PM
That is a super-nice install. Quality parts and quality workmanship. Some will not even see the extreme attention to detail you put in. Very nice work. Keep us updated.
TT 1997 Cobra vert
wicked5_0 is offline
post #11 of 51 Old 03-02-2007, 12:17 AM
All I have to say is WoW..
heedz up is offline
post #12 of 51 Old 03-02-2007, 09:35 AM
nice ride bro. which intake are you going with?
'90 coupe on me too welds with M/T's, 306 shortblock, Anderson n-91, Mildy ported canfeild heads, victor 5.0 intake, c-4 w/4k stall,3.73 gears on the squeeze. almost done..
WTB: Victor nitrous plate kit!!!
lumberjack TR is offline
post #13 of 51 Old 03-02-2007, 02:45 PM Thread Starter
I went with a Hogans upper and TFS R lower.
Heres a pic of my home made oil catch can setup. No longer running a PCV
post #14 of 51 Old 03-02-2007, 03:54 PM
CMcCarthy's Avatar
What kind of ends are you using for the coolant passages to the heater core? I'm particularly interested in what you used on the rubber hose ends.
Charles
post #15 of 51 Old 03-02-2007, 04:20 PM Thread Starter
8an to barb for the smaller heat hose and 10an to barb for the larger hose
http://store.summitracing.com/partde...5&autoview=sku
post #16 of 51 Old 03-02-2007, 04:30 PM
damn they make a nice intake. how much did that run you?
post #17 of 51 Old 03-02-2007, 04:36 PM Thread Starter
New there 950. I got this one off Ebay for 800 with only dyno time.
post #18 of 51 Old 03-02-2007, 04:42 PM
damn! ill stick with a trickflow R upper and lower or something similar
post #19 of 51 Old 03-02-2007, 05:21 PM Thread Starter
If your turbo'd a good aftermarket intake is the edelbrock victor jr.
post #20 of 51 Old 03-02-2007, 06:45 PM
strokercharged95GT's Avatar
edit: NM
Car looks great, I hope that stock block stays together.
2013 Mercedes GLK-350
strokercharged95GT is offline
post #21 of 51 Old 03-02-2007, 09:17 PM
you mean the victor 5.0 efi intake?
thats what i was thinking about running. ive used it before on my last stroker setup. niiiice intake
post #22 of 51 Old 03-02-2007, 10:21 PM Thread Starter
Yeah, thats the one. They have so many I get confussed sometimes.
I also hope the block stay in one peice. My luck it will self destruct on start-up
post #23 of 51 Old 03-22-2007, 12:16 AM Thread Starter
more progress
Since my intake is flipped I had to re-wire the inj harness and throttle linkage. My friend made me the cable guide that I bolted to thebottom of the TB. Notice no more TB gaskets. Plate is o-ringed on both sides. Pretty happy how it all turned out. Should have more progress tom.
post #24 of 51 Old 03-22-2007, 11:17 AM
CMcCarthy's Avatar
I'm totally down with the o-ring idea. Excellent thinking.
Charles
post #25 of 51 Old 03-25-2007, 05:56 PM
Gabe's Avatar
Nice.
Gabe Davila
93 Lime Green Coupe RIP 11.2 @127 all motor
95 Turbocharged Cobra
90 Titanium coupe
Gabe is offline
post #26 of 51 Old 03-25-2007, 05:57 PM
Gabe's Avatar
U are running 42lb injctors?
Gabe Davila
90 Titanium coupe
Gabe is offline
post #27 of 51 Old 03-25-2007, 09:47 PM
Blackfive0's Avatar
Trader Feedback: (62)
That is one nice ride. I give you an A+ for how clean it looks and taking your time to do it right. I think I am a little jealous
Blackfive0 is offline
post #28 of 51 Old 03-25-2007, 10:27 PM Thread Starter
Thanks guys! It's been over 3 years and I cant stand looking at it apart anymore so it needs to get done this spring. I'm going to try the 42's out I figured if my L made over 450hp on them safely then they should be ok on this setup.
post #29 of 51 Old 03-25-2007, 10:49 PM
thats one sweet setup you've got there. keep up the good work
2004 gt-needing a blower
2000 gmc sierra. 88mm, forged 370 ls1 etc...
fullthrottledan is offline
post #30 of 51 Old 03-26-2007, 04:40 PM
I was wondering what you used on the hard line side?
Oh and, the car is sick man. Very inspiring.
C!ph3r is offline
post #31 of 51 Old 03-26-2007, 08:33 PM Thread Starter
I used 1/2 rolled aluim from summit. Then got tube sleves to connect to the an fittings.
Hope that helps
post #32 of 51 Old 03-26-2007, 09:41 PM
got ya. cool. thanks for the help.
C!ph3r is offline
post #33 of 51 Old 03-31-2007, 10:33 AM Thread Starter
more updates
Got a little bit more done. Installed my be cool rad with flex-a-lite fan. I made brackets for the fan and rad hold down. Welded in a bung into the rad for the coolant sender for the fan. Also relocated my intake temp sensor to the intake pipe. Hope to have her running sumtime in April. Heres a few pics.
post #34 of 51 Old 04-02-2007, 07:35 PM
just noticed the placement of your filter element. just curious as to why you didn’t put it in the fender or some other place outside of the engine bay? i would think with the amount of heat you are going to be producing in the engine bay you would want it to get the coldest air it could. i understand the air will be getting forced into an intercooler but i would think the colder the initial air intake charge, the colder the air would already be that the intercooler would have to work with. Just curious.
Again, your car makes me sick.
C!ph3r is offline
post #35 of 51 Old 04-02-2007, 08:27 PM Thread Starter
I wanted to but where the turbo sits there isn't enough room to run a pipe down . I did cut/hollow out a old stock light to use when I'm at the track to try and ram cool air in. I hope the intercooler cools well lol. Thanks for the comments!
