f-cam from stock? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 02-25-2007, 12:34 PM Thread Starter
f-cam from stock?
tossing around the idea of an f-cam as I still run a stock one.
What idle rpm are you guys running with the F-cam with out the car shaking?
what kind of rpm range are you guys running in an f-cammed street car?
currently I'm not going over 5500 to keep the stock block intact.
MOOVS is offline
post #2 of 13 Old 02-25-2007, 12:47 PM
Idle was 800 rpm for and I shifted mine at 5500-5600 rpm.
skip nay is offline
post #3 of 13 Old 02-25-2007, 12:47 PM
millhouse's Avatar
At around 900 RPM the car has a slight rumble to it...perhaps a tad more than stock. 850 RPM was quite a bit more pronounce...but still docile. Under 800 and you could really feel the shake...and it sounds great to boot!
2016 Ruby Red Mustang GT PP
Prior Cars
millhouse is offline
post #4 of 13 Old 02-26-2007, 05:43 AM
Erich's Avatar
Your car would be a good before and after test for the F cam. Well documented before the swap-numbers would be meaningful.
Erich
Erich is offline
post #5 of 13 Old 02-26-2007, 11:22 AM
90LXHatchback's Avatar
I idle around 1100 rpms.. And shift around 6400 rpms..
F-cam sounds great down low on idle..
Good Luck..
James..
DSS 306, S-trim pullied to 15lbs., Tremec 5 speed, Edel. RPM 2, 42lb. inj., 65mm TB, 90mm MAF, Trick Flow Heads, 1.6RR, Comp Cams HP Nitrous Cam, 8.8 w/3.73, 509rwhp 470rwtq
90LXHatchback is offline
post #6 of 13 Old 02-26-2007, 04:38 PM Thread Starter
6400 Yikes!! stock block=split.
Damn I gotta build another motor for more power
MOOVS is offline
post #7 of 13 Old 03-03-2007, 08:53 PM
smurfmobile8586's Avatar
I would go with the f cam over the stock cam,, I have heard that also, there are lots of people saying not to spin over 6k
smurfmobile8586 is offline
post #8 of 13 Old 03-03-2007, 09:30 PM
Erich's Avatar
rpms kill way more than power.
Erich
Erich is offline
post #9 of 13 Old 03-04-2007, 12:39 PM
Corral Member
My idle was set at about 850. I liked it, fairly smoothe. Shifted at 6500 to 7000. Yes stock block, yes 142 mph, crossed the traps at around 6300 to 6500.
Toma
Incon TT 5.0 Stock Short, 9.79 and best of 142.5mph. Pump Gas A9L 383w 9.26 @ 151
Toma is offline
post #10 of 13 Old 03-06-2007, 10:22 AM Thread Starter
I never run mine over like 5500 in hopes of it staying together till I get a boss block built.
Damn thats fast Toma! glide or c4 or aod? rear cogs?
Dyno #'s?
MOOVS is offline
post #11 of 13 Old 03-06-2007, 10:19 PM
pkstang's Avatar
Trader Feedback: (161)
Dyno #'s?
how long have you been running those numbers and keeping the rpms down?
pkstang is offline
post #12 of 13 Old 03-07-2007, 10:53 AM
U.S. Air Force RETIRED
Matt Grieve's Avatar
Trader Feedback: (88)
Erich
Exactly....
1990 Mustang GT
2004 Mystichrome Cobra
2015 Mustang Ecoboost
2015 RAM 2500 Cummins
Matt Grieve is offline
post #13 of 13 Old 03-11-2007, 10:01 AM Thread Starter
I run a dual stage boost controller that activates the Meth at the higher boost level. so in everyday driving I only have like 425-450rwhp but if I flip the switch I get the bigger #'s.
2 summers now, aprox 7-10K miles.
I do find myself flipping the switch alot more now though.
This summer I think I'm going to try some chip tunning in hopes of leaning it out a little below 4700rpm as currently it's super rich. I don't know if the hp # will go up but I'm hoping for 700rwtq.
MOOVS is offline
