Help!!! ASAP - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 02-10-2007, 01:45 PM Thread Starter
Help!!! ASAP
My trouble is that originally this set-up was running great. Everything was working great, etc. Now, I'm having a lot of trouble getting it to run correctly. What happens is when you get on the pedal the turbo will spool, you'll start to see alittle power and then right at about 3,000 RPM it falls on its face. I can hear a small amount of blow-off. My first thought was the fuel system I had the injectors cleaned, replaced the fuel filter, etc. and still the same thing. My other thought is that the wastegate is remaining open and not allowing any boost to build. Its a really annoying dilemma considering the motor and turbo was working excellent and then this problem developed for no apparent reason. Should I install an aftermarket fuel pump?
I'm just at a dead end, and since this is mostly my brothers car he is getting to the point where he wants to sell it. I don't want him to, but it is his car. I figure by getting it running up to par again his urge to sell it will disappear. The actual set-up is listed below.
# 1986 2.3 Turbo Merkur Motor Swap
# 5spd Trans.Swap
# Holset Hy35w Turbo ported wastegate
# Volvo Wastegate Actuator
# Fully Ported And Polished Head
# Unshrouded valves
# 35 lb/hr Injectors
# Gutted Upper Intake
# Ported and Knifed Lower Intake
# K&N Filter
# Homemade Cold Air Intake
# Stock Forged Pistons
#Total Seal Rings Gapless
# Engle 111 Cam
# Homemade Adjustable Boost Valve
# Pk1 ECM
# Small VAM
# A/C Delete
# Removed Air Box and Silencer
# Bailey Evo BOV
# Adjustable Clutch Cable and Quadrant
# Custom Dual Supercoupe Intercooler
# 94-95 65mm TB
# Ranger 95amp Alt and Bracket
# Explorer Radiator
# Tauras Fan w/Manual Switch
sk83r005 is offline
post #2 of 2 Old 02-10-2007, 04:09 PM
Scones's Avatar
actually sounds like a leak somewhere...check all your vacuum hoses and silicone connectors
1986 5.0TT Tribute Car
2010 Ranger 4.0
1989 Kawasaki Ninja ZX6
Scones is offline
