Help me please - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 02-07-2007, 11:41 AM Thread Starter
Help me please
i've got a buddy who is going to sell me the T25 turbo off of his 97 eclipse GS-T, and i was wondering what all i would have to do to bolt it up to my 96 GT, obviously routing the intake and exhaust to and from the turbo, for that i plan on just buying the piping and cutting it myself and having a friend weld it, i mean like fuel system upgrades, ECU progamming i will probably just go with a custom tune but if there are any programs/programers out there that would work for this please let me know, rerouting any hoses, timing adjustments, cooling system? i plan on running about 6-8 lbs just to keep it on the safe side also do i need forged internals to run that amount of boost or would i be safe with stock? i plan on using it as a daily driver except in bad weather, any imput is welcome as well as part prices and where to find them
thank you
Fast281GT is offline
post #2 of 6 Old 02-07-2007, 12:12 PM
That turbo is too small for your engine.....Don't waste your time....
TFScoupe is offline
post #3 of 6 Old 02-07-2007, 12:20 PM
Erich's Avatar
+2 on that. Just think of it this way: divide your motor size by the mitzu motor size and that is going to be the minimum number of mitzu turbos you need (very roughly speaking). Bottom line-even as a twin setup, that is going to be small. You want either a pair T3s or a much bigger single.
Also, it is a little involved building a turbo setup for a mod motor car. You will either need to run pipes below your K member or get a tubular one to get clearance.
Erich
Erich is offline
post #4 of 6 Old 02-07-2007, 12:56 PM
Scones's Avatar
too small, and with your questions you are too new to turbos to even try. spend a few months reading and posting over at www.turbomustangs.com before you even start spending money. a turbo isn't a basic bolt on and there;s a lot to learn to do it right...
1986 5.0TT Tribute Car
2010 Ranger 4.0
1989 Kawasaki Ninja ZX6
Scones is offline
post #5 of 6 Old 02-08-2007, 03:06 AM Thread Starter
thanks thats why i asked
post #6 of 6 Old 02-08-2007, 06:43 AM
Erich's Avatar
Good to ask. Here are a few observations:
In my experience, it is really funny, when you go to build a kit, the first thought is always, "gotta go get a turbo" and then rush rush rush. That is what I did. Basically, all I knew was T-bird turbos work to make killer twin turbo 5.0 mustangs. Also I knew there are 3 flavors of Tbird turbos. Since my original idea was to build a cheap junkyard turbo setup, off I went to the local yard that had an 88 T-bird with a good turbo, pulled it and the manifold and paid 90 bucks. That turbo is an IHI which is one of the smallest tbird turbos. Now, I was locked in to find a second same one. Got that and off onto the build. The build itself and the other things associated with the setup now in retrospect were WAY more involved and in some cases more costly than obtaining the turbo. For example, originally I was going with a "free" fuel system: 140 lph intank pump, a spare procharger inline pump that was kicking around, an fmu that I bought for 45 bucks and stock 19# injectors. Ok not free, 45 bucks. Once I had my setup built, I was just floored by the amount of power you can get out of turbos, it is totally and utterly amazing. Now with all this power, I have this ify fuel system that has to run at 100 psi to supply fuel. With everything else working and driving so nice, I did not want to wreck my motor. So now, I go and buy the proper 42# injectors (230), PMAS maf (160), 255 lph pump (125) and all of a sudden I have 600 plus into a proper fuel system and 200 bucks into turbos! Of course, I wound up rebuilding the turbos myself so that was another 300 for parts and balancing. In retrospect, I probably should have waited and searched out the largest .63/.60 Tbird T3s but I think my setup is working really well with what I have. I can always build TT setup version 2.0..........
Anyway think ahead and plan. Think about your power goals. If you want, fast spooling hard hitting turbos but do not mind about 400 rwhp and 500 rwtq, the small bird turbos will work good. If you are dead set on 500 rwhp and up, you need the big uns. What is funny is the initial turbo cost will be the same or very similar!
Erich
Erich is offline
