Blow-Thru setup questions - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 21 Old 02-04-2007, 01:36 AM Thread Starter
Had a couple questions about my build for a blow thru set up.
1. the bov has to go before the maf correct? (pic to show setup)
2. 4 inch of straight pipe before and after the maf should be enough currect?
Notes. i know the pipe before and after the maf has to be the same size as the actual maf in order to get a proper reading. any imput welcome. thanks in advance.
boooost94 is offline
post #2 of 21 Old 02-04-2007, 03:18 PM
Trader Feedback: (30)
Hahaha, nice picture. Setup is fine, I think you'll have better luck with a bit more pipe before the MAF to have a better reading.
-'90 Mustang LX Coupe 5.0 SSP. 83 DSO US Gov't Issue. H/C/I Track toy
93Krwy is offline
post #3 of 21 Old 02-04-2007, 04:11 PM
red89coupe's Avatar
Trader Feedback: (31)
I agree, prolly atleat 12 in of stright pipe before and after the MAF. Well thats what I was told by the person doing the chip/tune on my car. He also asked me to use SCT MAF over the PMAS. Ask the person who is going to tune it what they prefer.
red89coupe is offline
post #4 of 21 Old 02-05-2007, 07:39 AM
Erich's Avatar
12 inch before the maf would be great. 4 inch is too little. I try and use 7 or more. Good idea too to see what the tuner prefers on the maf. Another choice would be to adapt a lightning maf.
Erich
Erich is offline
post #5 of 21 Old 02-05-2007, 07:59 AM
I only got 4-5" of straight pipe before my 3"pmass and it works flawlessly.
MOOVS is offline
post #6 of 21 Old 02-05-2007, 06:17 PM Thread Starter
thanks guys!
post #7 of 21 Old 02-05-2007, 06:54 PM
Thats how I have my turbo set up. I have 5 inch (roughly) of straight pipe and works great. Bov position is fine as well. Happy boosting.
65 Mustang
68 Barracuda 440
boostdidfox is offline
post #8 of 21 Old 02-05-2007, 10:40 PM
Blackfive0's Avatar
Trader Feedback: (62)
I would say at least 5 or more I had about 4 on mine and it make tuning a pain.
Blackfive0 is offline
post #9 of 21 Old 02-07-2007, 11:35 PM Thread Starter
ok, i've been doing some reading, and i know that you must have the same size intake piping before and after the maf. how close must it be? i mean here the the inch to mm convertion, the closest i could get the a lmaf, 90mm.......3.5000 88.9000 is that close enough as far as the piping size goes?
post #10 of 21 Old 02-08-2007, 02:19 AM
With using a blow-thru setup it isn't necessary to use a huge mass air meter like it is running a draw-thru setup. A 3" or 3.5" blow-thru Pmas would be better in my opinion. Like with my PT-67 P-trim setup on my fox, i'll be using a PMAS 3" blow thru since that is the same size as the tubing from the turbo/ intercooler.
93Krwy is offline
post #11 of 21 Old 02-08-2007, 06:08 AM Thread Starter
o alright, i have a pro m race maf. does anybody happen to know if that can be used in a blow through set up?
post #12 of 21 Old 02-08-2007, 09:07 AM
I had somewhat of the same concerns. I had an 80mm LMAF and used 3" cold side piping. My biggest concern was actually getting the metal adapter flange to seal against the mass air meter. I slathered it with Ultra Copper but I still don't like the look of it.
Ended up buying a 12" long piece of 3" aluminum and an aluminum MAF adapter so I can still use the LMAF sensor. That way I know it'll seal and the cold side piping is 3" all the way through.
mustanggreg is offline
post #13 of 21 Old 02-08-2007, 12:15 PM Thread Starter
so u just took the sensor out and installed it into the 3inch pipe? i didnt relise you could do that. any more info on this?
post #14 of 21 Old 02-08-2007, 12:23 PM
botlrokit93's Avatar
Trader Feedback: (26)
MAF setup
Hey guys, not to hijack here, but I didn'y know you needed a length of straight pipe AFTER the MAF. How critical is this, and can you tune around it? I might have to break out the welder again! Here is a pic of my setup. thanks!
AARON
_______
botlrokit93 is offline
post #15 of 21 Old 02-08-2007, 12:30 PM Thread Starter
how close is that pipe to the size of the maf? just wondering how close it needs to be. i mean, is within .1 of the mm size good enough? that seems to be the closest i could find. 3.5 inch pipe is like 88.9 mm. close enough to 90 right? or will it throw it off
post #16 of 21 Old 02-08-2007, 12:33 PM
awdgsx's Avatar
You can do pretty much anything you want after the maf..
awdgsx is offline
post #17 of 21 Old 02-08-2007, 12:36 PM Thread Starter
ya i agree. since you have a pretty straight shot before the maf, i doubt you will have any trouble, if anything it will peg out a little sooner
post #18 of 21 Old 02-08-2007, 06:03 PM
thanks guys! i was a little concerned.
AARON
_______
post #19 of 21 Old 02-08-2007, 08:07 PM
I bought one of these:
http://www.vmptuning.com/store/index...d=34&parent=31
and a piece of aluminum piping. It'll be welded to it and the sensor bolts right to it.
post #20 of 21 Old 02-09-2007, 10:43 AM
SeriousSN95's Avatar
Trader Feedback: (25)
get a univer and itll solve any problem u have with blowthru trust me i went through all the nonsense already lol
95 Rio Red5.0- Twin Turbo sold
90 notch- 400w 14.1-glide' gutted traded
2000 gt SOHC pump gas 11.50s on NUTS
2001 terminator clone,4v teksid,tr3650,irs,turbo
SeriousSN95 is offline
post #21 of 21 Old 02-09-2007, 04:42 PM Thread Starter
thats what im trying to figure out. i have a pro m race, can that be used in both blow through and draw through?
