Bypass valve VS Blow off valve - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 01-17-2007, 11:20 AM Thread Starter
VIPERBLUELX's Avatar
I currently have the large red Procharger race bypass valve and the thing is freakin LOUD driving down the road, it sounds like a jet which is cool, but cruising at 80 on the interstate it almost drowns out the radio. I'm thinking about selling it and getting a blow off valve so it will only make noise when the throttle snaps shut, instead of venting all the time it see's vacuum. Is there any reason's I shouldn't swap it for a blow off valve?
Mark
98 SVT Cobra 610rwhp/632rwtq Hellion T76
VIPERBLUELX is offline
post #2 of 4 Old 01-17-2007, 02:43 PM
I always thought the difference between the blow off valve and bypass valve was bypass was routed back into the system and blow off was in the atmosphere.
I have a dsm bov and I don't hear it until you get into boost then let off.
1994 Turbo GT
mustangless is offline
post #3 of 4 Old 01-17-2007, 05:03 PM Thread Starter
blowoff valve is spring loaded and only vents after you've seen boost and you let off the throttle, bypass valve vents anytime the valve is seeing vaccum.
post #4 of 4 Old 01-30-2007, 08:07 AM
i dont see a problem as long as you are running blowthrough.
boooost94 is offline
