turbo newbie question about oil feed/return - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 01-09-2007, 02:31 PM Thread Starter
vbstng's Avatar
i bought my turbo kit used and im new to the whole thing, it didnt come with oil feed/return lines. and i was wondering where to run the olines to?? where is a good place to purchase them ,and do you have a part number or anything??? pics too if possible..
thanks very much im going crazy!!
vbstng is offline
post #2 of 6 Old 01-10-2007, 12:35 PM
I was sure this had been answered before, and I was trying to dig up the posts so I could simply provided you links to them, but I'm not finding what I am looking for, so.....
The oil supply line requires attachment to a source of pressurized oil in the block. Most people simply put a "T" on the end of the spacer that the oil pressure sensor uses to attach to the left front (driver side) of the block. This allows for the sensor to remain functional, while providing oil.
You route the line however you feel like routing it, so that it is safe from damage.
Oil supply lines are usually small (-3AN or -4AN) steel braided or small copper (bathroom plumbing) or steel (brake/fuel) hard lines in a 1/8 or 3/16 (roughly equivalent inside diameter to -3AN and -4AN respectively).
Type of line used is generally dependent on budget, durability desired, acceptable appearance, etc... of the user.
Performance shops (ie. Summit, some local shops depending on locale) are good sources of steel braided lines (AN's) whereas everyday parts and hardware stores can be sourced for hard lines.
Fittings are always the fun part of the puzzle, since there are multiple different thread subsets, so going from one measuring scale to another requires attention to detail.
Many people will advice the installation of a compact filter near the turbo, many people ignore this, many people do not, there are security benefits to running an inline filter at/near the turbo, but it in the end it is up to the user.
Connecting the oil feed to the turbo sometimes requires special fittings/adapter plates, other times you can simply screw a hose fitting into the inlet. Depends on the turbo.
Sometimes a .040" - .060" restrictor is required on the oil feed, sometimes not.
Oil drains should be around a 10AN (1/2") and should also be connected to the turbo according to the design of the turbo, and the drain should connect back to the engine at the highest point on the oil pan that you can connect it. It is technically possible to drill and tap the timing cover for a drain connection, but it is generally easier to attach the drain to the pan. Drain hoses can be made of any oil compatible material of adequate diameter.
The oil drain must be rather smooth in curvature from the turbo to the pan, with the line as vertical as possible.
Drain lines connected to the valve covers, oil pan drain plug, pressurized oil passages in the block, oil level sensor, etc... will not work, at least not without separate catch cans and sump pumps, etc.....
Pope is offline
post #3 of 6 Old 01-10-2007, 12:49 PM
stephen_wehner's Avatar
what kit do you have?
stephen_wehner is offline
post #4 of 6 Old 01-10-2007, 02:20 PM
run -3 feed drill and tap the stock oil sender that screws in the side of the block on the 302.
-10 drain tap or weld fitting to pan
Newt-Rod is offline
post #5 of 6 Old 01-10-2007, 02:38 PM
Scones's Avatar
This will be the minimum requirements for a twin set up, cust in half for a single.
oil lines and fittings
jeff at ponydown.net set me up with the stuff which saved me a lot of time.
here you can see the braided feed lines coming from the port where the oil pressure guage is
you'll also need to tap the pan like so, or have a bung welded on
1986 5.0TT Tribute Car
2010 Ranger 4.0
1989 Kawasaki Ninja ZX6
Scones is offline
post #6 of 6 Old 01-22-2007, 11:50 AM
Big Top GT's Avatar
Trader Feedback: (37)
I'm getting ready to order some from www.vsracing.net.
Each kit consists of the restrictor, feed line, return line, and all the fittings.
They're 99 bucks each.
Hope this helps,
Alan
98 Cobra Coupe ~ Back to square one: no motor.
2006 Lotus Exige - 1.8 litres of Supercharged fury!!! SOLD!
Originally Posted by ATOMONKEY
If you don't want to take my word for it, maybe you'll believe the internet.
Big Top GT is offline
