finally got the car started!!!!! basic tune question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 01-01-2007, 12:53 PM Thread Starter
brian15's Avatar
ok so heres the combo
stock bottom end
performer heads with 1.9 valves
crower 15511 cam
performer rpm2 intake
with a base hellion kit
install went pretty smooth
i do have an exhuast leak between the down pipe and the turbo that i need to fix .
but my main question is like base settings f/p , timing and stuff ?
i know i can clock the mass air to help with idle and stuff
should i just set timing at 10* , or are you guys setting it and running timing locked out ?
fuel pressure ?
any ideas , experience or info would be great
thanks
brian15 is offline
post #2 of 13 Old 01-01-2007, 01:19 PM
Blackfive0's Avatar
Trader Feedback: (62)
Before I go my car tuned I set my fuel pressure at 38 and lock the timing in at 20*.
Blackfive0 is offline
post #3 of 13 Old 01-05-2007, 10:30 PM
slowblown5.0's Avatar
Same as above---just stay out of the boost until you get it tuned.
73 CJ5 408W, 4sp Toploader, 9" locked up front and rear
03' MG Cobra, 2.9 whipple, T56 Magnum, Mcleod RXT, 591/540
slowblown5.0 is offline
post #4 of 13 Old 01-06-2007, 08:05 AM Thread Starter
brian15's Avatar
got ya .... i just want to get it to idle decent well run decent enough to move around the driveway and get this pig out of the garrgage ..... then its of for tunning
thanks guys
brian15 is offline
post #5 of 13 Old 01-25-2007, 06:33 PM
How are you planning to tune it?
You might look into this: http://www.xpinnovation.net/products.html
The stock computer and a TimingLock will work great on a setup like yours.
89 GT : 420rwhp/452rwtq @ 10 psi.
EricHughes is offline
post #6 of 13 Old 01-25-2007, 07:00 PM
Scones's Avatar
if you want to run spout in set timing at about 5* and then turn it up a degree or two if you aren't getting any knock
1986 5.0TT Tribute Car
2010 Ranger 4.0
1989 Kawasaki Ninja ZX6
Scones is offline
post #7 of 13 Old 01-25-2007, 10:19 PM
Until you get it tuned, definately keep it fat and the timing down just a bit...I just set the timing at 7*, put the spout back in and if you have a fuel pressure gauge, adjustable regulator, and an FMU, I'd set the fuel pressure to about 90psi at WOT....Probably won't make the most power with these settings, but will keep it pig rich and in the safe zone till the custom tune...
TFScoupe is offline
post #8 of 13 Old 01-26-2007, 07:27 AM
Erich's Avatar
You did not mention your fuel system! What injectors are on there? Timingwise you have heard a bunch of reasonable suggestions. My setting fall into the same range: 18 BTDC with spout out or 6 BTDC and put spout back in. The idle stuff is likely to be MAF/injector/fp related. The turbo stuff should not affect idle.
Unless you have your fuel system upgraded to 255 lph pump, matched maf and 36-42# injectors, don't let it get into boost or you may be pulling off your stuff to change headgaskets etc.
Erich
Erich is offline
post #9 of 13 Old 01-26-2007, 07:56 AM Thread Starter
brian15's Avatar
sorry guys .....
my fuel system is a 255 pump , 42lb injectors and an aeromotive regulator .
the meter is the c&l unit that came with the kit .... havent messed with clocking it but the car is idling great as it is now ....
just sittin on jack stands ...... 10* timing with spout in rite now ..... f/p is like 32 with vacum .....
is it safer to run spout out now and set it at 20* ?
thanks for the info guys ..... if i can get my cooler lines ran , im going to creep around this weekend and ill get ya some pics
brian15 is offline
post #10 of 13 Old 01-26-2007, 09:07 AM
EVIL5LITER's Avatar
A few words of advice:
1) Add an inline pump to your setup. You're going to need it.
2) Just leave the timing at stock, put the spout back in it, and DON'T STEP ON IT UNTIL YOU GET A TUNE. Real simple.
EVIL5LITER is offline
post #11 of 13 Old 01-26-2007, 09:47 AM
Originally Posted by brian15 View Post
sorry guys .....
I'm not sure if I'd run 20* of locked out timing yet....I'd just set it at 6 or 7* and put the spout back in....I've experienced with several turbo cars, and usually they perform and drive better with the spout in.....Now, you say your going to "creep" around this weekend...Dont fool yourself, you have new power and will be tempted to get a heavy right foot....Do yourself a favor and set you car up rich on purpose just to be safe until the tune...Any time I've put a blower or turbo on a new setup, I've always ran low timing and alot of fuel pressure at WOT until I could get to the dyno....I've never had to change headgaskets or split a stock block....You don't want to have to change headgaskets a week or two after you just put on the new kit...
TFScoupe is offline
post #12 of 13 Old 01-26-2007, 09:53 AM Thread Starter
brian15's Avatar
yea thats very true .... but i do need to move it out of the garrage .....
i need to let me tuner know a week in advance then take the car to him to have it tuned ..... then the real run begins ...
our track opens the first week in march and i should be ready
brian15 is offline
post #13 of 13 Old 01-26-2007, 01:46 PM
Erich's Avatar
The most conservative way with the timing is to set it at 18 and leave the spout out. They do run somewhat better with it in but if you do that, no more than 6 BTDC. Driving it around is a little hard not to get on it that is for sure but don't. 255 lph pump should be fine imho-pretty common setup.
Erich
Erich is offline
