Modular Turbo Cams?, using stock cams, specs inside. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 12-27-2006, 03:50 PM Thread Starter
Ok guys,
Last time my thread went to a crap match on whos car was what post count this and that, Im smarter than so and so and a bunch of other non important info.
Lets keep on subject.
I was planning on using a set of custom grind cams for my turbo 4.6 4v but with all the pissing and moaning about stock cams decided to see what was available.
here is a list of all the stock cams and specs that I could find...
https://www.corral.net/forums/showthread.php?t=865811
since the exhaust and intake cams are seperate on the 4V heads which combo or set of Intake and Exhaust cams would make the most sence to use.
20psi
4.6
7.5k redline
heads flow 300+ int/ 260+ exh
idle quality insnt that important
Note: I HAVE TO PURCHASE A SET OF CAMS ANY WAY SO STOP TRYING TO "SAVE ME" AND SAY THE ONES I CURRENTLY HAVE -AS I DONT OWN ANY DAMMN CAMS CURRENTLY.
Thanks In Advance.
360 Notch for ur LS1 is offline
post #2 of 2 Old 12-28-2006, 08:48 AM
DNA
Cams
I have a two valve and rather than guess I went to Comp Cams gave them the motor specs Turbo size boost RPM's and had them custom grind mine cams. Costy was not bad it ran me right around 700 bucks and I had them in a week. I bought them thru Razor's Edge in Ft Lauderdale, Fl.
Good Luck
DNA is offline
