cant belive the numbers - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 15 Old 12-24-2006, 06:30 PM Thread Starter
that turbos produce i mean im amazed on stock internals get 500 to 600 hp to the groung. i run with supercharger and i would have been lucky to 350 on a stock motor on 9 psi . so i guess i going have to change my set up i think i have mostly everthing i need but will some one let me if im wrong
306 all forged interianals
h/c/i
30 lbs inj proble a little small i was thinking on 42
80mm mass air
70 tb
tremec 3550 tko
373 going to be a little step but i have 355 in another rear end or should i go 308
i m getting like 490 at the motor now how much would i expect to get out
of a mp t70 .68 set up and would i t be worth a change i have another stang to put the stuff i have to change any input would be great
thanks art
merry x mas to all
pup50 is offline
post #2 of 15 Old 12-24-2006, 09:15 PM
Trader Feedback: (25)
go with at least 42's if not bigger, the 3.08 gears, and an .81 housing on the turbo. it will help out a lot on a motor with good heads and intake. 450 to the wheels if not more would be easy with a decent tune...
2slow93gt is offline
post #3 of 15 Old 12-26-2006, 01:50 AM
Do you have to have good heads and intake to make power?
I'd hate to mess up heads if the stock block came apart.
MOTORCITYMADMAN is offline
post #4 of 15 Old 12-26-2006, 10:47 AM
red89coupe's Avatar
Trader Feedback: (31)
NOT NEEDED!!!but with them you can make more power with less boost.
I hate to mess up good heads, or forged interianals!!!!!! stock interinals and heads have been proven to produce enough power to split the block when used with a turbo.The block is the weak link.
red89coupe is offline
post #5 of 15 Old 12-26-2006, 05:05 PM Thread Starter
holley heads intake ,main girdle windage tray
pup50 is offline
post #6 of 15 Old 12-26-2006, 05:21 PM
The down side to more boost? Do you need a really good tuner to pull it off or you better off with a better intake package?
So confusing.
Only restriction would be it would have to run on pump gas.
post #7 of 15 Old 12-26-2006, 06:55 PM
red89coupe's Avatar
So confusing.
The ONLY down side to more boost is the stock block..hehe
A good tuner is allways a great idea!!!!!!
IF I was sticking to pump gas then stock H/C/I prolly wouldnt be enough..Thank goodness we have 110 at the pumps here without access to race gas I prolly would do a intake or head swap.
pup50.. I would be really careful !!You will be close to the limits of the block and when it goes it usually takes everything with it.. A gridle just keeps all your broken parts in a nice little pile..
post #8 of 15 Old 12-27-2006, 12:45 AM
Scones's Avatar
If you're making 4900 at the motor right now N/A I wouldn't bother boosting, you're already pushing the limit of the stock block (albeit the low limit) with those numbers...
1986 5.0TT Tribute Car
2010 Ranger 4.0
1989 Kawasaki Ninja ZX6
Scones is offline
post #9 of 15 Old 12-27-2006, 02:52 AM Thread Starter
i am new to turbo but if someone will give me a number to talk sky is the limit im 28 and make67grand i have a budget but im old school i want to do as much as i can
pup50 is offline
post #10 of 15 Old 12-27-2006, 07:47 AM
red89coupe's Avatar
I agree with Scones !!!! 490 is in the dangerzone lol
IF the budget is no limit, why is it you seem to be going "lowbuck"??
with NO limit on spending...Dart block, turbonetics turbo, water to air intercooler, BIG injectors, a standalone engine mangt system and ALL the top of the line goodies would be the way to go. It all depends on how much HP you want..
post #11 of 15 Old 12-27-2006, 09:40 PM
What do you think you could get with stock H/C/I on pump?
I think Holley intake is $600 and heads like TW run $1,100 or so. Thats alot of extra money for how much extra power considering the stock block?
post #12 of 15 Old 12-28-2006, 12:13 AM
the t 70 is roughly 20-30 whp per psi, it depends on the combo, there are cars making 500 whp with 8-10 psi on bone stock motor, im hopeing to do it with 5-8 psi, ill let everyone know soon, im making 310/340 na
sprayed88 is offline
post #13 of 15 Old 12-29-2006, 06:20 PM
Thumbs up
Sweet. Keep us updated.
Personally I'd like to do a stock engine and just add boost. I'd hope I can make 400 RWHP on pump.
post #14 of 15 Old 12-30-2006, 12:57 AM
red89coupe's Avatar
Thats EXACTLY what Im doing !! but 110 comes out of the pump here
stock longblock and a 62-1....
post #15 of 15 Old 12-30-2006, 05:44 AM
87fiveoh254's Avatar
My friend had an untouched 200k mile motor and added the hellion kit and got 405hp/443tq with a flat 11 a/f ratio. His name on here is lilmayo if you wanna search for the thread, but it was a while back.
2007 GT
87fiveoh254 is offline
