turbo's - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 18 Old 12-14-2006, 02:39 PM Thread Starter
turbo's
What is the best twin combination to run to reach 1000+ RWHP? I have a 331 that is built to take it. I have heard twin T3/t4 are good any more?
stang393 is offline
post #2 of 18 Old 12-14-2006, 02:46 PM
what kind of block and internals do you have?
and for the turbos there are many many different combinations you could go with to reach those goals
red1994turbocobra is offline
post #3 of 18 Old 12-14-2006, 04:00 PM
pintoman351's Avatar
Trader Feedback: (28)
two 62-1's will work.
pintoman351 is offline
post #4 of 18 Old 12-14-2006, 09:10 PM Thread Starter
I am not worry about the block and internals. I know they can take it. I was looking at Garrett T3/60-1 w/ .82 a/r. What ya think.
stang393 is offline
post #5 of 18 Old 12-14-2006, 09:17 PM
i hope thats not a stock block
90gs500 is offline
post #6 of 18 Old 12-14-2006, 10:01 PM
Depends on what you want to do with the car...street, track car. The T3 housings don't flow very well on high revving, big cammed, well flowing heads. I'd consider going with a T4 hot side with an A/R dependant on Expected rpms. I'm using TO4E 60 trims with .68 a/r T4 P trim housings on a 383W.
post #7 of 18 Old 12-15-2006, 12:17 PM Thread Starter
Does Garrett make a t4/60-1 w/.82a/r? pintoman who makes you turbos. . also did you make the kit or buy one? Thanks for all the help
stang393 is offline
post #8 of 18 Old 12-15-2006, 05:55 PM
in the old T series, the new GT series are a better turbo but pricey with ball bearing option. I'm using Masterpower turbos for my build. Seriously dude, consider T4 turbine side, if you have a built engine the T3 will be too restrictive. My build
https://www.corral.net/forums/showthread.php?t=856984
here is a link to the MP turbos.
http://partsexpressonline.com/shop/i...a26a046d488981
post #9 of 18 Old 12-16-2006, 01:44 PM
What block are you using with your 331 setup? And what pistons, crank and rods?
1,000hp is more than a forged 331. You really need the best of everything if you are honestly looking to build a reliable 1000HP engine.
post #10 of 18 Old 12-18-2006, 07:36 PM Thread Starter
Dart block and billet crank, rods ect...
stang393 is offline
post #11 of 18 Old 12-19-2006, 09:17 PM Thread Starter
i found a 62-1 / P Trim / T4 A/R.96. But do ya think a .96 A/r will be to big? I was thinking along the lines of a 81 A/R.
stang393 is offline
post #12 of 18 Old 12-20-2006, 12:52 AM
what heads, what are you gonna be spinning this motor to (rpms)?
post #13 of 18 Old 12-20-2006, 08:44 PM Thread Starter
I am running TF high ports. Looking to turn around 6500-7000 RPM's.
stang393 is offline
post #14 of 18 Old 12-20-2006, 11:42 PM
yrtneg24's Avatar
Trader Feedback: (25)
check member name "wolverine" on turbomustangs.com.......
yrtneg24 is offline
post #15 of 18 Old 12-21-2006, 10:11 PM Thread Starter
ya he has a bad ass car. I want to know if a 96 a/r is to big. should I go with a 81 or something?
stang393 is offline
post #16 of 18 Old 12-22-2006, 12:35 AM
if its a race motor i might go the .96 a/r but if its mainly for the street i'd go with the .81
post #17 of 18 Old 12-22-2006, 08:28 AM
xr8240's Avatar
Two XTR T4E-70 - T04Z with .84 housings..
xr8240 is offline
post #18 of 18 Old 12-22-2006, 05:15 PM Thread Starter
Thanks guy you have help me out big time now I just need to find out were I am going to buy them from. I think I am going to go with the T04Z's.
stang393 is offline
