Anyone relocate alt to drivers side - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 19 Old 11-30-2006, 04:07 PM Thread Starter
brian15's Avatar
well was curious if you have done so or could point me in the rite direction to find a kit ....
need to make the hellion kit work with no ps or a/c
thanks guys
brian15 is offline
post #2 of 19 Old 12-01-2006, 08:34 AM
smurfmobile8586's Avatar
threre is a kit that summit sells its for somthing other then a mustang do a search on it and somthing might come up, also someone on here i cant rember who helped me out when it was thinking about doing the swap there is an address in the thread "www.summit.com"
smurfmobile8586 is offline
post #3 of 19 Old 12-01-2006, 08:36 AM
post #4 of 19 Old 12-01-2006, 06:08 PM Thread Starter
brian15's Avatar
Originally Posted by smurfmobile8586 View Post
thank you ....i think i found another way to do so also ...its a march performance bracket kit that moves your tensioner to the drivers side and it looks like everything would work with it .....
thanks again
brian15 is offline
post #5 of 19 Old 12-01-2006, 07:12 PM
U.S. Air Force RETIRED
Matt Grieve's Avatar
Trader Feedback: (88)
moroso make s kit as well...pm 8sec90gt on here, he has run it
1990 Mustang GT
2004 Mystichrome Cobra
2015 Mustang Ecoboost
2015 RAM 2500 Cummins
Matt Grieve is offline
post #6 of 19 Old 12-01-2006, 07:54 PM
hey brian send me a llink to what you have found i have been thinking about doing it for some time now
thanks
post #7 of 19 Old 12-02-2006, 12:46 PM Thread Starter
brian15's Avatar
http://www.marchperformance.com/pg30.html
item number 1460 ....
i measured everything and with the hellion kit that will work on my car .....
brian15 is offline
post #8 of 19 Old 12-02-2006, 12:54 PM
1460 is an a/c elim bracket? i have no powersteering or a/c just a alt, water pump, tensioner and the crank pulley
post #9 of 19 Old 12-02-2006, 04:08 PM Thread Starter
brian15's Avatar
ahh but it can be used either way .... if you go on that link and click on install instructions it shows both ways ......it can be used with a p.s pump and no a/c or without either .....
what are you trying to do with you set up ?
brian15 is offline
post #10 of 19 Old 12-02-2006, 05:32 PM
Smile
ahh read the instructions
sorry not used to doing that
thanks
post #11 of 19 Old 12-02-2006, 05:33 PM
I want to move the alt to the driver side so i can get a bigger exhaust housing for my turbo
post #12 of 19 Old 12-02-2006, 05:34 PM
daily driver setup
post #13 of 19 Old 12-03-2006, 08:16 PM
Custom bracket similar to the Moroso piece. I tried the March setup first. Couldn't get it to work without squealling. This setup works great for me.
sn9550 is offline
post #14 of 19 Old 12-03-2006, 08:19 PM
another picture.
sn9550 is offline
post #15 of 19 Old 12-06-2006, 09:17 AM
very, very nice you said it was a custom piece did you make it? looks great again!
post #16 of 19 Old 12-07-2006, 04:39 PM
No, I just came up with the design. A machinist friend made it for me and I polished it.
I still have the Moroso kit less the two spacers and rodends/turnbuckle if your interested.
sn9550 is offline
post #17 of 19 Old 12-29-2006, 11:19 PM
hulk8950's Avatar
sn9550, clean set up! I likes!!
I have a few concerned Q's.....you are using a forward rotation water pump and timing chain cover ...right?
Besides your stock reverse rotation pump..
And Has your 1 and only bolt that keeps the belt tight and holds your alt in place break yet?
I ask this because I've delt with mods like that before and after many times of fishing out the the broken bolt in the head, i gave up and made a brace using 2 bolts on the water pump to the main bolt on the alt.
That put a halt to that prone breakage real quick!
'89 TTGT 306, canfeilds, F-cam, 1.6rr, edelbrock perf intake, 76 C&L, 65mm TB, 42# inj, self fab'd twin T60's, MSD 6AL, stock ECU(no chip/ piggyback), home built C4, 3.50 gears, 9", 27X10.5's, 3500#, 9.94/136mph on 14psi
hulk8950 is offline
post #18 of 19 Old 12-30-2006, 09:36 AM
Yes it's a standard rotation pump. I heard about the Moroso stud breaking that's why I came up with this particular design. By using the two bolt bracket on the head I was hoping to move the shear force off the threads of the bolt. So far so good. I only put about 1500 miles a year on my car so I'm sure that helps.
Do you have picture of your setup?
sn9550 is offline
post #19 of 19 Old 12-31-2006, 12:47 AM
jcg9777's Avatar
Trader Feedback: (51)
I got my kit from breeze automotive and put it on last week. It works well and allows you to use your stock style reverse rotation water pump. Here is a link:
http://www.breezeautomotive.com/deta...d=158&cat_id=8
1991 Coupe: Dart Sportsman 331, AFR205's, Holley Systemax, Hellion T76 turbo kit, TKO, PMS and other extras.
1993 Cobra: 52K, Black/Grey cloth #4740, SOLD
jcg9777 is offline
