what did your car run n/a before boost? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 20 Old 11-28-2006, 12:02 PM Thread Starter
brian15's Avatar
figured i would just run the question by everyone im gettin very anxious with my turbo install ....
anyone have any times before they added boost .....
my car on my 17inch cobra wheels and street tires was going 12.80's at 110-111 ....... and that was with my 3.27 gears and rpm2 intake and all .....
im throwing 10lbs of boost down it with a trans brake and a couple other goodies , should be interesting to say the least ....
anyone have examples ?
brian15 is offline
post #2 of 20 Old 11-28-2006, 12:22 PM
mpe331lx's Avatar
331
afr165s
#24s
Cobra intake
3.55s
I have never made a good pass with the car, But went from a 13.1 @ 109 to a 11.65 @ 125 with the clutch slipping most of the pass.
I added a stock pullied S trim/ power pipe/ #42s and a tune (and removed about 100 lbs )
DSG 03 Cobra
DSG 97 Camaro
96 Cobra: Stock Longblock 4.6 4V, KB2.8H, T56, 9.93 @ 142
mpe331lx is offline
post #3 of 20 Old 11-28-2006, 08:58 PM
428GT's Avatar
Mine went 11.54 @ 124 NA on 17 DR's...I can't wait to get the turbos on
428GT is offline
post #4 of 20 Old 11-29-2006, 10:37 AM
My car went 14.01 at 104mph n/a
...went 11.95 at 123mph on 10psi
This was a '94 cobra with stock longblock with all the bolt-ons and a turbo.
red1994turbocobra is offline
post #5 of 20 Old 11-29-2006, 03:36 PM
blown8950's Avatar
I was going 9.40's @ 76 in the 1/8th.
Now, 8 psi of turbo boost later and no other changes, I'm going 8.30's @ 95 in the 1/8th, both runs on 17" street tires, not drag radials. I'm pretty happy with a 20 mph gain in the 1/8th, but I really want "just" 5 mph more!!
1989 LX: Vortech YS-Trim blown DSS 347, Stage 3 Twisted Wedges, Holley Systemax 2, AFM B-451 cam, AFM Power-Pipe, AFM PMS, 80mm Pro-M, Aeromotive 1000 hp fuel system, Precision Turbo 65 lb/hr injectors, UEGO 1000 Wide Band O2, MSD 6BTM and Distributor, 33-spline Moser axles and spool, Bogart Drag-On Stars, UPR Chromemoly K-member and A-Arms, Kooks 1-7/8", Dr. Gas, 130 amp alt, etc.
1991 GT Convertible: stone stock, PA AOD, Edge Converter, 62mm Turbo, 397 rwhp, 458 lb./ft rwtq @ 8 psi
blown8950 is offline
post #6 of 20 Old 11-29-2006, 05:32 PM
15.1 at 94mph to 12.84 at 109, 7psi
1994 Turbo GT
mustangless is offline
post #7 of 20 Old 11-29-2006, 07:10 PM
JIMS SVT's Avatar
10.79 @ 126.7 before...Cant wait to get this turbo project done.Even though I just started.lol
1998 turbo cobra TH400 Street car Sold
1997 Triple black Novi2k 6 speed car.
1999 FRC Cammed C5
JIMS SVT is offline
post #8 of 20 Old 11-30-2006, 03:58 PM
91StangCoupe's Avatar
I went straight for boost. I figured with small cam, LC and a carb set up for boost, I'd be disappointed anyway...
1991 Blow-thru turbo Coupe 1.41 60ft - 6.71 @ 105 1/8 mile - SOLD
1989 GT - SOLD
1990 LX - Being prepped for paint
91StangCoupe is offline
post #9 of 20 Old 12-16-2006, 02:44 PM
92' GT 351 H.C.I Stock drivetrain 3:08 gears best of 13.90/99 at 5800ft. Added T-70 with 7 pounds went 12.10/ 118 still stock drivetrain.
turbo351fox is offline
post #10 of 20 Old 12-20-2006, 01:06 PM
mid to high 12s @ 108 NA
120+ w/9# pt76 boost
99Cobra
DIY Turbo
See pics on my homepage
ubeenbit is offline
post #11 of 20 Old 12-20-2006, 03:33 PM
n/a- 1.62 short time [email protected]
9 lbs-1.84 leaving on stock axles to a [email protected] after i ran outta gear just before the 1k ft mark
86 coupe, 408,glide 101mm
810rwhp pumpgas tune...........
90lx351 is offline
post #12 of 20 Old 12-21-2006, 01:18 PM
biminiLX's Avatar
Interesting...I went [email protected] NA 427" on DRs
I'm only adding one turbo though...88mm Precision T6
-J
'91 LX hatch
Bimini Blue
427"/88mm at 16 psi
biminiLX is offline
post #13 of 20 Old 12-21-2006, 11:06 PM
428GT's Avatar
Mine are small though...hows your set-up coming along?
428GT is offline
post #14 of 20 Old 01-02-2007, 08:34 AM
NC STANG GUY's Avatar
Trader Feedback: (176)
Not a turbo but..
357ci that was in my coupe,[email protected] n/a with a 5spd
[email protected] with 12psi from a YS Vortech,carb blowthrough setup and a C4 trans.
NC STANG GUY is offline
post #15 of 20 Old 01-02-2007, 08:55 AM
millhouse's Avatar
The last time I ran down the track I clipped off a 13.4 with the stock long block and nitto's. Lord knows what I'll do know with 10 lbs of boost! If only I could keep from breaking sh^t to find out!
2016 Ruby Red Mustang GT PP
Prior Cars
millhouse is offline
post #16 of 20 Old 01-02-2007, 08:10 PM
hulk8950's Avatar
With my old extremly ported, large valved, '65 289 heads i did a best of [email protected] N/A. By just replacing the old '65 heads with bone stock '97 P heads with a mild port match it then went [email protected] with 9psi. I was taking the motor to the stock rev the whole pass. So far that was my first and only time down the strip with boost. I have since dyno'd it and found my max power was an early 5300.
'89 TTGT 306, canfeilds, F-cam, 1.6rr, edelbrock perf intake, 76 C&L, 65mm TB, 42# inj, self fab'd twin T60's, MSD 6AL, stock ECU(no chip/ piggyback), home built C4, 3.50 gears, 9", 27X10.5's, 3500#, 9.94/136mph on 14psi
hulk8950 is offline
post #17 of 20 Old 01-10-2007, 10:01 PM
FLBoostAddict's Avatar
13.2/106mph with stock T-5
10.97/122mph with PTK kit, Art Carr AOD, and 26x8.5 M/T ET Drags
1990 Mustang GT (93 Cobra Clone) HOK KandyTangerine. October 2008 MM&FF Feature Car
[email protected] (Pony Wars @ SGMP2010) - Old combo
New build in works: Fordstrokers Dart 347 with twin Precision 6766CEA's and Hughes PG
FLBoostAddict is offline
post #18 of 20 Old 01-11-2007, 12:04 PM
Steed93's Avatar
I went 12.7 @ 106 mph before the turbo setup. Back then, I had Dart Sr. iron heads and a small Crower 511 cam with the Holley intake. Swapped in a stock cam and the TFS heads when I went turbo.
1993 LX hatch
11.21 @ 124
480 whp, 520 wtq (10 psi)
Steed93 is offline
post #19 of 20 Old 01-29-2007, 02:42 PM
biminiLX's Avatar
Hey man, your car is looking good. I still plan on a single, but twins like yours would be nice. Could you PM me here or HC50 with the cost breakdown for twins?
Here are pics of mine---should have updates this weekend:
http://bbs.hardcore50.com/vbulletin/...ad.php?t=37069
-J
'91 LX hatch
Bimini Blue
427"/88mm at 16 psi
biminiLX is offline
post #20 of 20 Old 02-18-2007, 12:56 PM
JIMS SVT's Avatar
Havent run the car but the new setup is making some good ower and the calculations are saying that on the street tune it should trap in the 145 range.Thats with 590 to the tire and not fully done tuning on it.Race tunes gonna be 20psi and race gas.In my street car.Should be fun.
1999 FRC Cammed C5
JIMS SVT is offline
