What to do bad idle? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 11-24-2006, 09:05 PM Thread Starter
smurfmobile8586's Avatar
Smile What to do bad idle?
I have 30# injectors and the fuel press is @35 just running a short down pipe off the turbo and its not connected to the exhaust yet, i pulled the plugs and the top of the ground strap is grey and the inside of the plug smell a little like gas? I have cleaned the maf timing is set at 14 with the spout out. i also have a 255 lph pump, Idle has a 300 +or- for a few seconds then shuts off, even after driving, push in the clutch and out like a light
smurfmobile8586 is offline
post #2 of 8 Old 11-24-2006, 09:09 PM Thread Starter
also i have tried regapping the plugs from 45 to 30 now it has no power and will not really rev up easy,
post #3 of 8 Old 11-24-2006, 09:59 PM
Trader Feedback: (30)
You need to back the timing waaaaaay down. Base timing being 14* on a turbo car is a bad idea. Run 8* base to start with, ~40psi fuel pressure with vacuum disconected. .035" on the gap for the plugs and you should be okay. Just make sure to go get a dyno tune within the near future so you don't melt down that motor.
-'90 Mustang LX Coupe 5.0 SSP. 83 DSO US Gov't Issue. H/C/I Track toy
93Krwy is offline
post #4 of 8 Old 11-25-2006, 08:04 AM Thread Starter
i am @ 14 with the spout out, i guess icould go to 8 with the spout in i guess, are you saying to run the car without the vaccum on the regulator? or are you just saying to set the fuel presaure that way thanks
post #5 of 8 Old 11-25-2006, 10:19 AM
He is saying to set fuel pressure with the vacume unhooked. On the timing you can set at 14* but leave the spout out and that will keep it from advacing so much. My distributor is locked meaning no timing advance. I recommed leaving the spout out and never put it back in, and then just adjust your timing on a dyno. Trust me your engine will last alot longer with no timing advance.
holdmeback is offline
post #6 of 8 Old 11-25-2006, 02:19 PM
blown8950's Avatar
I'd lock the timing at 18 degrees to start (set it at 18 and leave the spout unplugged), re-gap your plugs to .035", and start with 40 lbs. of fuel pressure. Also, if you're running a C&L meter, you can try re-clocking it to help with idle/drivability issues. Rotating it clockwise should richen the mixture, rotating it counter-clockwise will lean it out. Also, if you intend to run any amount of boost, those 30's are likely not going to cut it.
1989 LX: Vortech YS-Trim blown DSS 347, Stage 3 Twisted Wedges, Holley Systemax 2, AFM B-451 cam, AFM Power-Pipe, AFM PMS, 80mm Pro-M, Aeromotive 1000 hp fuel system, Precision Turbo 65 lb/hr injectors, UEGO 1000 Wide Band O2, MSD 6BTM and Distributor, 33-spline Moser axles and spool, Bogart Drag-On Stars, UPR Chromemoly K-member and A-Arms, Kooks 1-7/8", Dr. Gas, 130 amp alt, etc.
1991 GT Convertible: stone stock, PA AOD, Edge Converter, 62mm Turbo, 397 rwhp, 458 lb./ft rwtq @ 8 psi
blown8950 is offline
post #7 of 8 Old 11-25-2006, 03:32 PM Thread Starter
Smile
i am running a stock 88 super coupe maf, i was wondering how to tell if it is maxed out or not i was told to check the voltage 4.99 or more and its maxed any ideas would be helpful. thanks
post #8 of 8 Old 11-26-2006, 06:17 PM Thread Starter
plugs are now at 35 still shuts off when trying to stop at a stop sign or somthing, if you keep you foot on the gas about a 1/2 or so it will surge but will stay around 1k -1300 kinda bouncing
