500HP possible with GT40 heads and intake? How close can I get?...... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 14 Old 11-12-2006, 09:13 PM Thread Starter
GTdriver's Avatar
I've got a complete 96 Explorer 5.0 engine sitting in my shop. It's the one with the standard gt40 heads, not the gt40p's. I'm thinking about pulling it down and maybe strengthening the bottom end a bit, pistons, rods, and a girdle. 306 or 331, either way is an option. Of course head studs, appropriate gaskets and whatever else it takes. My main question is can I see 500rwhp and how much boost will it take. I just built a 306 with edelbrock heads and a vortech s-trim @10psi that made almost 450rwhp, so I know or at least I think or hope it's possible on a gt40 motor with a turbo. What kind of boost should I be trying to make? I'm basically looking to get the most power for the money. What are my options here?
GTdriver is offline
post #2 of 14 Old 11-12-2006, 10:01 PM
jonboy688's Avatar
there is going to be no set number for how much boost=x amount of power. but i think a master power t70 will be the best bet in your app. its cheap and does the job. i would say its going to take close to 15psi to make 500whp just my 2 cents
94 Gt street car
jonboy688 is offline
post #3 of 14 Old 11-12-2006, 10:19 PM
I made 463 with a hellion kit on a stock motor with 12lbs of boost. I would think 500 would be pretty easy with same boost on the 306 motor with better heads and intake, and that is with a 62mm turbo
alkyholic is offline
post #4 of 14 Old 11-12-2006, 10:42 PM
You don't need great heads to make good power with a forced induction setup. You'll be able to reach that goal very easily.
Clevor finished!! Now on to everything else...
phate is offline
post #5 of 14 Old 11-12-2006, 11:53 PM Thread Starter
GTdriver's Avatar
Well, I know that you can't specify an exact amount of boost, but around 12-15 psi wouldn't be bad at all, I think this is the way I'm gonna go
GTdriver is offline
post #6 of 14 Old 11-13-2006, 07:52 PM
i made 480 rwhp with 9 lbs on my 351w with gt40's. i figure im at about 540-550 rwhp on 12 lbs now
86 coupe, 408,glide 101mm
810rwhp pumpgas tune...........
90lx351 is offline
post #7 of 14 Old 11-19-2006, 06:47 PM
I made 506rwhp and 575rwtq at 5500rpm's with my 91 ex 4cylinder, i have sock motor with arp heads studs and felpro mls gaskets, gt-40 intake, e-303,70mm tb, 38lbs injectors and t70 pony downd turbo kit, the hp was at 12psi with a diablo revolution chip.
95lightning is offline
post #8 of 14 Old 11-20-2006, 08:50 AM
Erich's Avatar
You should not have trouble hitting 500 hp. Twin garrett .60/.63s will do the trick.
Erich
Erich is offline
post #9 of 14 Old 11-23-2006, 06:50 PM
blown8950's Avatar
I making 396 at the rear wheels, probably 460 or so at the crank @ 15% parasitic loss through the drivetrain, with a totally stock 77,000 mile 5.0 engine with just a 62 mm turbo and only 8 psi boost. I'd say it's totally possible. Turbo boost is a beautiful thing!!
1989 LX: Vortech YS-Trim blown DSS 347, Stage 3 Twisted Wedges, Holley Systemax 2, AFM B-451 cam, AFM Power-Pipe, AFM PMS, 80mm Pro-M, Aeromotive 1000 hp fuel system, Precision Turbo 65 lb/hr injectors, UEGO 1000 Wide Band O2, MSD 6BTM and Distributor, 33-spline Moser axles and spool, Bogart Drag-On Stars, UPR Chromemoly K-member and A-Arms, Kooks 1-7/8", Dr. Gas, 130 amp alt, etc.
1991 GT Convertible: stone stock, PA AOD, Edge Converter, 62mm Turbo, 397 rwhp, 458 lb./ft rwtq @ 8 psi
blown8950 is offline
post #10 of 14 Old 11-25-2006, 11:00 PM
chris123's Avatar
Trader Feedback: (43)
When i pulled the T-trim off my 358 cid motor it was making 555rwhp with 10 psi. I went turbo intercolled and with the same boost level of 10 psi the car made 618rwhp. Turbos a driven by engine waste ie exhaust, superchargers take power to make power. It would not surprize me if you took the s-trimoff and went turbo you would be at 500rwhp! My .02
358 cid Dart block (8.2 deck) foxlake ported Victor Jr's
Victor 5.0 Anderson b4 cam BBK long tubes TKO 600
Anderson Motorsports YSI 8/2.95 10 rib setup
755RWHP @ 6750 RPM'S on pump gas & meth
chris123 is offline
post #11 of 14 Old 11-26-2006, 10:49 AM
Heres what I made with ~15psi with my cartech street sleeper kit w/ t64e turbo. GT40X heads, stock cam, and cobra intake on 302 ford crate motor
[IMG][/IMG]
GT40X is offline
post #12 of 14 Old 11-26-2006, 01:49 PM
either run twin turbo's or a nice T76 turbo and get er' done!
Omega Doom II is offline
post #13 of 14 Old 11-26-2006, 02:58 PM
It's possible with e7te heads, stock intake and stock cam.
stanggod is offline
post #14 of 14 Old 11-26-2006, 04:42 PM
good lord thats awesome!
