Quick balance question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 02-17-2006, 10:00 AM Thread Starter
I have asked this before, but i will be starting the car on saturday(FINALLY!!) and i need to know what to listen for to see if the wheel hits the housing. When i had the turbo off the car, i had some shaft play, but i pulled it to one side and spun it and it did not hit the housing, and i assume with oil in there things will tighten up. The person i bought it from said it has a slight whistle on idle, but i didnt see fine metal shavings or evidence that it hit the housing. What do you think that whistle could be? i do have that small chip in one of the fins, could that be it?
fastwhite86gt is offline
post #2 of 3 Old 02-17-2006, 03:47 PM
gt93mustang's Avatar
If it spins free and doesn't hit the housing, it should be fine.
gt93mustang is offline
post #3 of 3 Old 02-17-2006, 06:22 PM
Erich's Avatar
The whistle should be normal. Good luck!
Erich
Erich is offline
