boost my anti drug - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 02-14-2006, 08:11 AM Thread Starter
need whelp with turbo set up?
i am picking up my 89 notch on weds. and have some questions.
this is what the car has.
gt 40 crate motor
gt 40 upper lower
gt 40 iron heads
B 303 cam
70 mm bbk T/B
73 mmC&L mass air
shorty headers
off road h pipe
flows dumped
bbk cold air
king cobra clutch
world class built t-5 tranny
welds
190 fuel pump
I am adding 3.55 gears 4 cyl springs u/l control arms lake woods shocks and struts 42lb injectors and fuel regulator.
i want to go turbo. I am liking the b&g turbo kit.Now the question is What kinda of power would i be putting down at 8-9 psi and turned up to 14-15psi?
thanks
thanks
nastynotch5.0 is offline
post #2 of 7 Old 02-14-2006, 11:37 AM
slowstang101's Avatar
i hope you upgrade the fuel system while your at it. That 190 aint gonna cut it
Dart Blocked SBF, PT106mm, Callies Magnum Crank, Oliver billet rods. New top end package in the works
slowstang101 is offline
post #3 of 7 Old 02-14-2006, 12:13 PM
Erich's Avatar
depends on the efficiency of the turbo. Also, if you don't upgrade that pump and injectors, you won't be going anywhere.
Erich is offline
post #4 of 7 Old 02-14-2006, 02:20 PM Thread Starter
i am going to do 39lb injectors and a 255 pump
post #5 of 7 Old 02-15-2006, 09:59 AM Thread Starter
post #6 of 7 Old 02-15-2006, 10:12 AM
39lb injectors? i havent heard of those. are they chevy? anyway, for that combo, i'd say you'd be in the 430ish rwhp range (depending on turbo) wiht 8-9 psi, and 500+ with the boost higher.
fastwhite86gt is offline
post #7 of 7 Old 02-15-2006, 11:19 AM Thread Starter
39 are 03-04 cobra stock injectors
