Post pictures of your DIY Turbo Set Up - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 31 Old 02-10-2006, 07:48 AM Thread Starter
Erich's Avatar
I'll start.
Erich
Erich is offline
post #2 of 31 Old 02-10-2006, 11:41 AM
twofast's Avatar
68 coupe
351W PT-88 E-98
700hp/643tq [email protected]
radials/street driven
twofast is offline
post #3 of 31 Old 02-10-2006, 12:51 PM
toxic283's Avatar
Anyone want to post a couple pics for me?
'86 GT 4.6 4V Turbo-SSO #2221. The Sponsors:
Ford Racing performance Parts-Jesse
Keystone Race Cars
Master security Corp East
toxic283 is offline
post #4 of 31 Old 02-16-2006, 09:27 AM Thread Starter
Erich's Avatar
Toxic283's setup
These were worth waiting for...
UPDATE FROM TOXIC281
Erich is offline
post #5 of 31 Old 02-16-2006, 03:07 PM
SICK
how much?
cheapartsguy is offline
post #6 of 31 Old 02-16-2006, 05:18 PM
A couple shots of mine....
'95 GT
-DSS low comp. 306/GT-40Y/Cobra U/L
-DIY Single Turbo - Holset WH1E @ 7psi intercooled
Powershift95GT is offline
post #7 of 31 Old 02-16-2006, 06:01 PM Thread Starter
Erich's Avatar
Cool! Not that many DIY sn95s. At some point I want to convert my 97 from blower to turbo.
ERich
Erich is offline
post #8 of 31 Old 02-16-2006, 07:58 PM
i'll get some of mine up when i can
fastwhite86gt is offline
post #9 of 31 Old 02-17-2006, 12:52 AM
Couple of my 87 vert
89ntrcptr is offline
post #10 of 31 Old 02-17-2006, 09:48 AM
The Hawk's Avatar
My friend's '86 GT. Flipped BBK's, 66mm Precision, all accessories and smog equipment still in place.
My Website:
The Hawk is offline
post #11 of 31 Old 02-17-2006, 10:06 AM
looks identical to mine, except mine is a t67
post #12 of 31 Old 02-18-2006, 01:40 PM
All of my build pics can be found on my website. It's a 351w twin turbo Holset HY-35. Aluminum heads, 5.0 HO roller cam, 1.7 roller rockers, forged pistons, 9:1 CR, modified powerstroke diesel truck intercooler, modified bronco oil pan, custom fuel rails, custom exhaust step tube logs, custom intercooler piping, custom v-band flanges, custom exhaust, custom upper intake, modified Professional Products Hurricane single plane carb intake. Megasquirt n spark extra PCM. Just finished it last weekend.. have yet to fire it up. That's this weekend's project. I still need to straighten stuff out in the engine bay to make it look a little better, but I'll do that after I get everything working properly. [/URL]
srvblues00 is offline
post #13 of 31 Old 02-25-2006, 07:41 AM
Is there a reason you dont see many DIY turbos on a 4.6? Ive really been thinking of switching from blower to turbo.
scarface is offline
post #14 of 31 Old 02-25-2006, 12:38 PM
lemosley01's Avatar
I've been investigating and watching because I'm considering going this route.
I think the main reasons is that 4.6L mustangs are still new compared to the Foxes. A lot the cars I have been seeing are 80s foxes. The nice thing though is that you can see what works and what doesn't and hopefully apply it to your own build, even if things have to be somewhat different.
The 4.6 also takes up more space (especially the DOHC). So it's a tighter fit.
And superchargers are so ubiquitous, proven, and (relatively) cheap, that most people simply go with what is known to work and not going to create a bunch of headaches.
1989 LX convertible - Tbird turbocoupe [email protected] K&N airfilter. Manual boost controller.
lemosley01 is offline
post #15 of 31 Old 02-26-2006, 05:45 AM Thread Starter
Erich's Avatar
There are no good reasons you don't see more turbo 4.6s. The pros: for a 4.6, you can run your stock block to much higher hp than 5.0s. Cons-worse stock rods and pistons compared to pre 93 5.0s. But pistons/rods are easier and cheaper than aftermarket 5.0 blocks. I think the other thing is a space issue. It is a little harder to run the pipes with the wider 4.6. That being said, someone on turbomustangs just ran everything under the crossmember and it really was not bad. If my procharger ever dies, my 97 will become a turbo car for sure.
Erich
Erich is offline
post #16 of 31 Old 02-26-2006, 10:06 AM
Blue92LX's Avatar
My mustang isnt near done so heres some of my escort. 15psi
01 Lightning
12.54 1.77 60 on F1's 427RWHP 533 TRQ
01 Mustang GT
13.8 stock
92 Lx 5.0
Underconstruction =)
DSS 306, AFR 185, FTI cam, custom turbo setup
95 Escort GT
[email protected] 300hp custom turbo
Blue92LX is offline
post #17 of 31 Old 02-26-2006, 11:20 AM
lemosley01's Avatar
Erich
Do you mean the K-member? Is that the guy the rear mounted the turbos, or is there a different car?
I just joined up over there because I am considering ditching my (as yet uninistalled) P1-SC for a DIY turbo. A good reason to learn how to weld.
post #18 of 31 Old 02-26-2006, 01:02 PM
Here's mine, all smog equip. and passed e-test[IMG][/IMG]
MOOVS is offline
post #19 of 31 Old 02-26-2006, 01:07 PM
OOPS! here's the right pic.
MOOVS is offline
post #20 of 31 Old 02-26-2006, 10:27 PM
If it's the one I'm thinking, he ran off the stock headers, and back under the k-member where it merged infront of the motor at the turbo. Pretty slick setup, and he says he doesn't have any real clearance issues with it.
'95 GT
post #21 of 31 Old 02-27-2006, 05:33 AM Thread Starter
Erich's Avatar
I'm not counting rear mounted turbos. Powershifted95gt is thinking of the right guy.
Erich
Erich is offline
post #22 of 31 Old 03-03-2006, 05:03 PM
91StangCoupe's Avatar
1991 Blow-thru turbo Coupe 1.41 60ft - 6.71 @ 105 1/8 mile - SOLD
1989 GT - SOLD
1990 LX - Being prepped for paint
91StangCoupe is offline
post #23 of 31 Old 03-03-2006, 10:57 PM
still in the works this pics about a month old...
02 F250 PSD superduty - The Mule no mods yet.
90 Hatch - Will never be done. best e.t. to date 10.30 @ 133 ;
86 Hatch - Made two track outings and was parted out best e.t. to date was 9.X @ 14X
Last edited by igotaneed4speed; 03-03-2006 at 10:58 PM. Reason: can someone pm instructions on how to hot link?
igotaneed4speed is offline
post #24 of 31 Old 03-04-2006, 12:37 AM
Meangrn92GT's Avatar
Trader Feedback: (62)
You all have awesome looking cars.
No belt on the car in the pic, just look over that part and yes I hate those plug wires as well.
Meangrn92GT is offline
post #25 of 31 Old 03-04-2006, 09:07 AM Thread Starter
Erich's Avatar
Nice setup. One thing you can do about plug wires is get the 90 degree make em yourself ones from summit. I ran them over the valve covers and dropped em down to the plugs. It comes out pretty neat. Before that I had the motorsport wires and was burning them up on the headers.
Erich
Erich is offline
post #26 of 31 Old 03-04-2006, 08:33 PM
Alex in Houston's Avatar
Talking
Lil Red 88 Coupe (just got done with it last week)
Green Machine 95 GT (should have the upgrades done and it back on the road before April)
Looking at the pics just now, it really looks like the 'cooler in the Coupe is larger. They're actually the exact same
Mr. M. M. Alexander
Originally Posted by Stopsign32v View Post
Stop crying, its just the internet. Life gets alot harder than some screen name on a message board not liking what you do to your car.
Alex in Houston is offline
post #27 of 31 Old 03-07-2006, 01:25 PM
http://www.ls1speed.com/danimal.cfm
sn95 cobra 347rblock T-56 twin turbo
f-304z heads,hydraulic roller
1075whp,[email protected]
[email][email protected]
danimal 95 is offline
post #28 of 31 Old 03-07-2006, 01:33 PM
GTPTim's Avatar
haha oops I didn't see this thread- I just posted my own thread:
https://www.corral.net/forums/showthread.php?t=766879
No in-car pics yet, but pics of my progress...
'88 Stang GT Vert
'92 Honda Civic Si Hatch, daily driver
GTPTim is offline
post #29 of 31 Old 03-07-2006, 03:49 PM Thread Starter
Erich's Avatar
Updated picture from Toxic281.
Erich
Erich is offline
post #30 of 31 Old 03-14-2006, 01:27 PM
heres pics of my diy sn95 http://www.ls1speed.com/danimal.cfm
post #31 of 31 Old 03-14-2006, 06:14 PM
Originally Posted by twofast
Very nice clean installation.
Just curious.... I have a couple of questions.
In the top photo, what are the vertical series of bolts for on each of the fenderwells that are just ahead of the strut towers?
What kind of speckled paint is that in the engine bay? I like it.
JimS is offline
