problem with boost - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 02-09-2006, 01:14 AM Thread Starter
Trader Feedback: (34)
problem with boost
this is on an 87 grand national, but same concept. car only goes to 4lb of boost then cuts off. i'm not good with turbo's and trying to learn. any ideas on what to check? wastegate, boost control, chip, etc.
scorp69 is offline
post #2 of 9 Old 02-09-2006, 03:11 AM
cuts off how? motor cuts out, motor shuts down, stumbles, what?
goes to 4 psi and runs fine but only hits 4 psi...more details please
sagep is offline
post #3 of 9 Old 02-09-2006, 11:53 AM Thread Starter
hits only 4psi and runs fine. the car runs fine, and hasn't really been able to get a good tune, but the turbo is only hiting 4lbs of boost.
scorp69 is offline
post #4 of 9 Old 02-09-2006, 12:53 PM
first thing would be to check all the connections to make sure you don't have a boost leak somewhere, then wastegate would be the next thing i'd look at.
91 lx hatch. Performer heads, Performer 2 intake, 1.7rrs, tfs 1 cam, pullied a-trim with power pipe, long tubes, orx pipe, and a magnaflow catback, [email protected] on 17" Nittos.
MediumRed91LX is offline
post #5 of 9 Old 02-09-2006, 05:44 PM
yep sounds like a leak. The wastegate regulates boost, so it might be stuck open. If that is fine the it will be on the cold side. Best bet is is a leaky fitting on your piping somewere or if those check out might be something with the BOV.
sagep is offline
post #6 of 9 Old 02-09-2006, 06:05 PM Thread Starter
alright guys, i'll check. when you say cold side, you mean the compressor side?
scorp69 is offline
post #7 of 9 Old 02-09-2006, 06:58 PM
Yes, compressor outlet to throttle body.
mustanggreg is offline
post #8 of 9 Old 02-09-2006, 07:16 PM Thread Starter
since your close by. would you mind helping out if you have time. i'm not to handy with turbo's.
scorp69 is offline
post #9 of 9 Old 02-09-2006, 09:06 PM
I'd bet the wastegate actuator is broken or come loose.
'95 GT
-DSS low comp. 306/GT-40Y/Cobra U/L
-DIY Single Turbo - Holset WH1E @ 7psi intercooled
Powershift95GT is offline
