What cam should i use with turbo? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 02-07-2006, 10:30 PM Thread Starter
Question What cam should i use with turbo?
Hey guy's, i will be instanling a ponydownd single turbo kit on my 91 coupe on next month, but i want to know what cam should i use on stock motor with 112,000 miles, i have a e-303 cam rigth now on it, but i was thinking about geting a x-cam, i know that stock cams make good power but i want to have a diferent cam. Thanks
-David
95lightning is offline
post #2 of 9 Old 02-07-2006, 11:35 PM
stay with the E.
fastwhite86gt is offline
post #3 of 9 Old 02-08-2006, 10:53 AM
I've been thinking about switching to an E from my stock one.
I'm with fastwhite86gt- stay with your E.
MOOVS is offline
post #4 of 9 Old 02-08-2006, 01:27 PM
i like my e
stangbro01 is offline
post #5 of 9 Old 02-08-2006, 10:14 PM
Blue92LX's Avatar
If your going with an alphabet cam I've heard the F cam to be a good turbo cam. But if your looking for the best overall performance run your E till you can afford a custom grind.
01 Lightning
12.54 1.77 60 on F1's 427RWHP 533 TRQ
01 Mustang GT
13.8 stock
92 Lx 5.0
Underconstruction =)
DSS 306, AFR 185, FTI cam, custom turbo setup
95 Escort GT
[email protected] 300hp custom turbo
Blue92LX is offline
post #6 of 9 Old 02-09-2006, 09:50 AM
Just leave the E in there. Definatley don't go for the X; it would just be a very poor fit for stock heads/intake (you said stock engine).
You could even go back to the stock cam if you wanted. The turbo will allow you split the block even with the stock cam, while maintaining excellent street manners.
1990 Mustang GT, Explorer shortblock with DSS MSS, Edelbrock Performer RPM heads, stock GT cam with 1.72RR, ported Explorer intake and 65mm TB, PTK T66 kit @ 18psi, AEM EMS + WBO2, Alkycontrol methanol injection: All Sold
Cld12pk2go is offline
post #7 of 9 Old 02-19-2006, 01:56 AM
Blackfive0's Avatar
Trader Feedback: (62)
I had and e-cam with 1.7 on my turbo car and it made good power all the way up to 6000rpm on dyno. I have been told more then once and seen it a couple of times that if you are going to run a letter cam with a turbo run a F cam.
Blackfive0 is offline
post #8 of 9 Old 02-19-2006, 02:19 AM
qwik88's Avatar
f cam if its a letter cam but deffenetly recomend custom ground
88 mustang lx paxton sn89 supercharger gt40 heads tremec 3550 pro 5.0 shifter holleysystemmax intake off road h pipe msd btm ignition box with boost retard mac shorty headers dynomax mufflers
qwik88 is offline
post #9 of 9 Old 02-19-2006, 12:27 PM
Since it's on a stock block, i'd just leave it in...people have broken stock blocks w/stock cams & 1.7rr with a turbo. No need in spending any more money than you have to. Getting a custom cam would be a good idea only if you have an aftermarket block.
my .02
Blk&Gld 94 GT is offline
