Who makes a Carbed Turbo setup/kit for 351? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 02-05-2006, 05:38 PM Thread Starter
Hey guys, i've been searching on here for some answers but can't really find anyway.
I want to do a carbed turbo setup probably witha single GT35R or GT42R, i don't want twins just a big single. Anyone steer me in the right direction?
Thanks,
MilenkoGT is offline
post #2 of 12 Old 02-05-2006, 05:43 PM
You do. Seriously, that's custom work, as far as I know. Pick a fan and start heating up the mig welder.
P51C
P51C is offline
post #3 of 12 Old 02-05-2006, 05:52 PM
Go to turbomustangs.com and check out their blow though carb section. Really all you would need is a tuner kit for a efi 351 and add your blow through carb and carb bonnet.
1slowaod is offline
post #4 of 12 Old 02-05-2006, 09:30 PM
Member
shiz302's Avatar
LOL P51 when I read the title I said the same thing to myself. " You do "
'97 SVT Cobra #178
Suspension wheels and exhaust.
shiz302 is offline
post #5 of 12 Old 02-05-2006, 10:27 PM
69Cougar's Avatar
http://www.toohighpsi.com/BudgetTT/BudgetTT.htm
I've done one (not for my car though, it went into a Pinto that runs 10's and looks like hell), and it is as easy as it sounds.
As long as I'm alive, I'ma live illegal
69Cougar is offline
post #6 of 12 Old 02-06-2006, 12:18 AM Thread Starter
Yeah i went to turbostangs earlier and looked at the CSU carbs, and the magnafuel fuelpumps etc... but the thing is how do you really tune on a carbed car. I could use a wideband to help me out but as far as the carb...does CSU have to know hwat turbo you are using?
post #7 of 12 Old 02-06-2006, 02:04 PM
The one I have helped out with was right on from csu. We have a wideband other than that its just jet changes.
1slowaod is offline
post #8 of 12 Old 02-06-2006, 11:19 PM
A GT35R isn't exactly a big single 650 WHP is as much as you're going to get completely maxing one out.
Black 1991 Notchback
Grabber Blue 2012 GT - HID's, Brembos, Nav
Red Metallic 2011 F350 Lariat CCSB
1000HP is offline
post #9 of 12 Old 02-07-2006, 12:22 AM Thread Starter
I'm looking to make between 600-700rwhp max enough to run low 10s, how about a T88 lol? I need to find a tuner kit as one of you stated and go from there i guess. Just the tuning part kinda baffles me with blow thru carbs using big fuel pumps etc...guess i need to read up more.
Right now i don't think my internals can handle the power... i have eagle SIR forged rods claimed to hold 700hp, and Keith black hypereutetic pistons which i have a feeling won't hold and the cast crank i'm not sure about.
What would be a good bottom end combo to go with?
post #10 of 12 Old 02-23-2006, 11:40 PM
monsterstang's Avatar
Im kinda in the same boat as you. ponydowns make a hotside single turbo kit for about 529 and add lik 50 bux for 351w. I am planning on using a T70 turbo with intercooler and meth/water injection to reach the 700 hp mark. As for a bottem end, im looking at JE sportsman pistons with a 27cc dish and eagle H beam 4340 rods and im still debating on a cast steel crank or a forged crank. as for the cold side, i was jus gunna get sum carb bonnet, custom make the intercooler piping and home mod my carb for blow thru.
http://ziptie007.phpwebhosting.com/c...roducts_id=183
/____ ____ ___\
( ]]] _ _ O _ _ [[[ )
|\_ o _ ____ __ o_/|
|___|.……....……|___|
monsterstang is offline
post #11 of 12 Old 02-24-2006, 06:16 AM
xr8240's Avatar
Try...
http://customcarbs.com/
http://www.superiorairflow.com/carb_...arburetors.htm
xr8240 is offline
post #12 of 12 Old 02-27-2006, 12:35 PM
Friend of mine here in town runs a 82 vette with homemade twin turbo with carb. He's runnin stock 350 chevy with two twin grand national turbos non intercooled with about 13 psi. He's runnin 600 vac sec holley with big jets to accopany the boost , loads up a litte at idle but he still drives it all the time an too the track to run 6.8 s in 8th!!
spoolinawdtsi is offline
