Would this exhaust be ok? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 01-25-2006, 11:29 AM Thread Starter
Blue92LX's Avatar
I want to keep the car looking sleeper, and was wondering if it is ok to run magnaflow mufflers. I still want to run my stock tips there 2.5. Will this hurt performance a lot? If so what are you guys running? Thanks
01 Lightning
12.54 1.77 60 on F1's 427RWHP 533 TRQ
01 Mustang GT
13.8 stock
92 Lx 5.0
Underconstruction =)
DSS 306, AFR 185, FTI cam, custom turbo setup
95 Escort GT
[email protected] 300hp custom turbo
Blue92LX is offline
post #2 of 12 Old 01-25-2006, 07:16 PM
As long as they are the straigh-thru design. You shouldn't have any problems with performance loss.
mfpmax is offline
post #3 of 12 Old 02-02-2006, 02:35 AM
chrisa351's Avatar
Magnaflow kicks ass. A dual 2.5 inch set up is good deep into the 10s easy.
I am currently welding up a 3.5 inch dp split into dual 3 inch magnaflows with dual 3 inch tailpipes under the axle cause of the antiroll bar.
I was running dual 3 inch bullets dumped before the axle. It was as loud as open DP dumped under passenger seat.
Good luck.
Anyone can sit in the stands and talk s**t. Get out there and RACE!!!
PT76GTS blowthrough...sold. Cool but not what I wanted.
was running a 14 to 1 Man O War 427 with High Ports.Sold.
now running a 412 Windsor with Vic heads and a .700 solid roller
chrisa351 is offline
post #4 of 12 Old 02-02-2006, 07:30 AM
Erich's Avatar
I'm running the supposed worst combo-cats (catco H-pipe) and 3 chambered flows. The car makes decent power 400 rwhp 490 rwtq with small turbos. I wonder if I am giving anything up with the exhaust as it is.
Erich
Erich is offline
post #5 of 12 Old 02-02-2006, 11:14 AM
DNA
Any buddy running no real exhaust?
I have been kicking around the idea of just running from the turbo exhaust side to under the front fender. Anyone running this way?
DNA is offline
post #6 of 12 Old 02-02-2006, 01:37 PM
Erich's Avatar
How about a cutout switch on the down pipe and dump that out the wheel well. You will be able to hear the turbos really nicely.
Erich
Erich is offline
post #7 of 12 Old 02-02-2006, 01:42 PM
U.S. Air Force RETIRED
Matt Grieve's Avatar
Trader Feedback: (88)
I ran mine with no exhaust for a bit...(couple trips around the block) and the turbo sang like crazy....I put 2.5 MAC produmps on it and its not that loud and still makes a ton of power like it did with no exhaust
FWIW- i had the stock cat-back on the car and made 430RWHP...and it was dead quiet
1990 Mustang GT
2004 Mystichrome Cobra
2015 Mustang Ecoboost
2015 RAM 2500 Cummins
Matt Grieve is offline
post #8 of 12 Old 02-02-2006, 06:14 PM
Erich's Avatar
It would be interesting to see what your dyno numbers are with the dumps or no exhaust.
Erich
Erich is offline
post #9 of 12 Old 02-02-2006, 07:27 PM
My downpipe dumps at the firewall, and the exhaust isn't loud at all until you get on it. It does whistle pretty good cruising around though. Only thing I don't like about the sound is it's kinda tractorish at idle. It's a very flat sound, especially coming from MAC pro-dumps for years pre-turbo which were fat and deep at idle. At every instance other than WOT, the open downpipe is WAY quieter than the pro-dumps were. It's nice to be able to carry on a conversation without yelling at my passengers over the drone.
'95 GT
-DSS low comp. 306/GT-40Y/Cobra U/L
-DIY Single Turbo - Holset WH1E @ 7psi intercooled
Powershift95GT is offline
post #10 of 12 Old 02-03-2006, 10:31 AM
DNA
Thanks for the input
I guess my next issue will be for the Wide Band sensor. The LM-1 says 3 feet after turbo and I think it needs to be before mufflers too.
DNA is offline
post #11 of 12 Old 02-03-2006, 10:41 AM
i've been looking at the dynomax straight thru 3" muffler for my setup but i've also been debating oben downpipe. can you guys hear the turbo spool/bov with the dp open? jc. mine will be running soon and trying to figure out what to do w/ my exhaust.
fastwhite86gt is offline
post #12 of 12 Old 02-04-2006, 08:09 AM
Heres what Im running on a 302 single t4. 3" dp to two 2.5 chambered pipe mufflers. They sound nice and rumbly like an NA motor and scream under full throttle.
http://pic17.picturetrail.com/VOL853.../124920901.jpg
More pics
http://www.picturetrail.com/gallery/...90&uid=3451677
Dedpedal is offline
