Shaft play - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 01-25-2006, 02:32 AM Thread Starter
Shaft play
Well my T72 has some shaft play in it.
What does that mean, is it still safe to run? Id like to get thru this summer and rebuild it next winter since im rebuilding my motor and doing alot of other things right now.
03BlackWidow is offline
post #2 of 3 Old 01-25-2006, 07:17 AM
Erich's Avatar
Is it side to side play or in and out?
Also, are your fins hitting the housing? If so, rebuild now. You are taking a chance not rebuilding. But then again it depends how much slop there is.
Erich
Erich is offline
post #3 of 3 Old 01-25-2006, 01:15 PM
Radial play should typically not exceed .90"-.110". If it does its time for a rebuild. We typically rebuild our customers and racers units once they reach that limit or .045-.055 on axial play as well.
Jose
JZ 97 SS 1500 is offline
