Cold Side Piping - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 01-23-2006, 09:19 AM Thread Starter
Cold Side Piping
Is is ok to make the cold side piping out of Mild Steel? Stainless mandrel bends cost a fortune and I cannot weld aluminum worth a crap. I just worry about it rusting, is this a concern, would powder coating inside and out work? Any help or advice would be great.
1965 Ford Falcon 2dr Hardtop Full PT Set-up - Build underway.
Dark Highland Green 2003 Supercrew 5.4 - Riding low and procharged
LowFast is offline
post #2 of 5 Old 01-23-2006, 09:37 AM
Mild Steel is just fine.
As for aluminium...if you plan out your pipng right...you don't need to weld a single pipe. You could use all silicone couplers to connect the piping.
mfpmax is offline
post #3 of 5 Old 01-23-2006, 09:44 AM Thread Starter
That is true, but this is on a truck and the piping is very visible. For show purposes I want to set it up as clean and smooth as possible, thus I am trying to eliminate as many couplers and connections as possible.
LowFast is offline
post #4 of 5 Old 01-23-2006, 12:18 PM
Erich's Avatar
You could powdercoat or paint it. I have good luck with tractor and farm implement paint (not kidding!)
Erich
Erich is offline
post #5 of 5 Old 02-08-2006, 11:06 AM
I used all mild steel then powdercoated everything.
MOOVS is offline
