Turbo + 10:1 compression? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 01-20-2006, 09:29 AM Thread Starter
LS2 KLR's Avatar
I'm looking at getting a t-76 setup soon and am worried about my compression. Without swapping pistons, I'm hoping to lower it slightly with thicker head gaskets.
I'd like to know about what I could expect with the t-76 and my setup? I won't be running any race gas in it but want to make at least 500rwhp.
LS2 KLR is offline
post #2 of 10 Old 01-20-2006, 01:51 PM
anyone with the new mach 1's have 10:5:1 pistons. the procharger kits out there for them, a buddy of mine has one. runs i think 8 maybe 10 lbs of boost and hit 450hp.
so your 10:1 can be done. just make sure you have a GOOD fuel systems, and a good TUNE.
Keeper9610 is offline
post #3 of 10 Old 01-20-2006, 02:10 PM
strokercharged95GT's Avatar
Youll be okay, i know the OHC motors are fine with boost and high compression.
2013 Mercedes GLK-350
strokercharged95GT is offline
post #4 of 10 Old 01-20-2006, 08:52 PM
Shouldn't be a problem, but the T76's on a 281 aren't in there sweet spot until you're close to 20psi or more. But regardless of your plans I'd consider some methanol injection. 500rwhp for a T76 is a bit overkill!!??, that thing will make 650-700 with your motor before breaking a sweat! Sounds cool though
2004 Redfire GT...PTE billet 71mm Turbo/Forged Alum. shortblock, custom cams, P51****sold to fellow Corraler****
2014 SGM A6 GT [email protected] CAI, Tune, off-road X, 19" DR's. Twin turbos coming for the fall of 2013.
WIPLASH1 is offline
post #5 of 10 Old 01-20-2006, 09:00 PM
xr8240's Avatar
Small bore motors get way with more compresion..The better breathing heads help..Your relying heaps on tune...Make sure detonation senser is working..
We have had 5.4 3 and 4 valve motors down under for some time, making good power numbers..
xr8240 is offline
post #6 of 10 Old 01-22-2006, 02:24 AM
privatejoker's Avatar
If you're going to have the heads off, you may want to consider some bowl work as well.
privatejoker is offline
post #7 of 10 Old 01-26-2006, 03:59 PM
all we americans got is the 4.6 unless we want to do a swap lucky but next year cant wait the shelby gt500 drool
GTman is offline
post #8 of 10 Old 01-26-2006, 04:38 PM
Yeah, some racers(in boosted OHC Mustangs) are actually finding that they run better with higher comp than lower comp.
post #9 of 10 Old 04-14-2006, 02:50 PM
supersexy00GT's Avatar
4v's LOVE high compression....talk to jim @vt engines and look on turbomustangs.com forums. youll find lots of good reads. all in the tune..on race gas youll be a MONSTER!
supersexy00GT is offline
post #10 of 10 Old 04-14-2006, 10:02 PM
xr8240's Avatar
In wouldn't fit thicker gasgets, it plays havoc with quench and can actually cause detonation..Think 400M motor...Low comp, low piston [in bore] to deck and detonate like crassy N/A !!!
xr8240 is offline
