Will this fuel setup be ok? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 01-17-2006, 08:58 PM Thread Starter
Blue92LX's Avatar
Im in the process of building up a single turbo 306. As of right now Im working on the fuel system. My plain is to run stock lines, 255 intank pump, aftermarket rails and 42# inj. My question is should I also run a 255 in-line pump? I've done a search and have mixed opinions. I also have all new aeromotive fuel system that I COULD use but I dont want to hear a loud pump whine all day long, and dont like the fact you cant go below 1/2 tank of gas. What do you guys think?
01 Lightning
12.54 1.77 60 on F1's 427RWHP 533 TRQ
01 Mustang GT
13.8 stock
92 Lx 5.0
Underconstruction =)
DSS 306, AFR 185, FTI cam, custom turbo setup
95 Escort GT
[email protected] 300hp custom turbo
Blue92LX is offline
post #2 of 4 Old 01-18-2006, 10:14 AM
Depends what kind of power and boost you want.
255 intank and 42's will support 500rwhp easy as I'm doing it with 36's and just a 255 in tank and all stock lines&rails.
MOOVS is offline
post #3 of 4 Old 01-18-2006, 12:15 PM
Steed93's Avatar
I would put in an inline pump just to be safe. The extra cost is much worth it rather than rebuilding an engine if you go lean by chance.
1993 LX hatch
11.21 @ 124
480 whp, 520 wtq (10 psi)
Steed93 is offline
post #4 of 4 Old 01-18-2006, 12:58 PM
Erich's Avatar
I would say the 255 in tank would do the trick. If you are running an fmu with small injectors, you may want the inline as well. I'm running a 190 lph plus an inline. I just needed more pump and had the inline sitting around.
Erich
Erich is offline
