? how much power is it gona make - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 01-12-2006, 10:10 PM Thread Starter
I wonder how much power a 416 winsor blown with twin y2k88's is gona make?
autofxj is offline
post #2 of 6 Old 01-13-2006, 05:55 AM
xr8240's Avatar
The turbo's flow enough to make 1500 h.p EACH I hope you have a good block and rotating assembly & tune..
http://www.turboneticsinc.com/turbo_y2k.htm
xr8240 is offline
post #3 of 6 Old 01-14-2006, 05:38 AM
there's really no telling? but if you were a top notch pro 5.0 or outlaw racer probbly around 1800-2200 HP or so?
Omega Doom II is offline
post #4 of 6 Old 01-15-2006, 11:25 AM
If you have to wonder, I would probably not suggest doing it
post #5 of 6 Old 01-20-2006, 08:08 PM Thread Starter
lol
I was looking for some replys. It should make about 2200-2400 HP. Cau should run 6.50's. Dart Block, Motorsport Nascar heads---- Pics soon
autofxj is offline
post #6 of 6 Old 01-20-2006, 08:27 PM
xr8240's Avatar
Seeing as turbo's don't actually make power on there own..With info above yes 2000+ h.p..WE weren't too far off..Good luck..Btw iron or alloy block ? Think weight saving...Yes $$$.....
xr8240 is offline
