New dyno numbers w/ retune... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 16 Old 12-30-2005, 11:46 AM Thread Starter
OshinDivr's Avatar
Had the car retuned at Speedy's Dyno in Owensboro. New numbers are as follows...
SAE - 411whp / 426wtq
STD - 428whp / 443wtq
Dynojet - 452whp / 468wtq
Power was made at 6-7psi.
Here's a video...
https://s6.yousendit.com/d.aspx?id=2...O0MKO3UET7M24G
1991 LX - Turbo 5.0
Old Combo...Stock block and heads, Turbonetics 62mm...6.78 @ 104.25 - 436rwhp/508rwtq @ 10psi
New Combo...Boss 347, TW heads, Super Victor, Cam Motion cam, Precision 78mm, Big Stuff 3, etc...
OshinDivr is offline
post #2 of 16 Old 12-30-2005, 12:20 PM
What was the power level before? It was at a lower boost setting, right?
post #3 of 16 Old 12-30-2005, 12:48 PM Thread Starter
OshinDivr's Avatar
The boost level was never completely nailed down. I had the 5lb. spring in the wastegate, but the gauge read as high as 11lbs. or so. On the dyno this time, we started out with the 5lb. spring, but the boost was all over the place, really erratic. We thought maybe the small spring couldn't control the boost. (Sidenote...with the small spring in there, the car made 467whp somewhere between 10-12psi.) We put the 7lb. spring in, and the boost leveled out dramatically.
1991 LX - Turbo 5.0
post #4 of 16 Old 12-30-2005, 12:59 PM
Do you think maybe the gauge is off somehow or it is something else?
post #5 of 16 Old 12-30-2005, 01:04 PM Thread Starter
OshinDivr's Avatar
The gauge was off previously, but was rewired before this tuning session. It matched up almost identically to what the dyno itself was reading during the pulls.
Something else to note, is that the car was originally tuned on an inertia dyno. This go round, it was tuned on a superflow dyno where the dyno can actually put a load on the car to simulate real world driving conditions.
1991 LX - Turbo 5.0
post #6 of 16 Old 12-30-2005, 10:31 PM
Whats the difference between these numbers? Why do they all vary and why do you use the STD numbers as your dyno numbers? What does STD and SAE mean?
Sorry, I just dont know the difference.
Jormungand is offline
post #7 of 16 Old 12-31-2005, 10:49 AM
props for [email protected]'s glad to hear someone on hear use him. What bottom end are you running I am looking to get 500rwhp with a turbo and was looking at peoples combos
pacebria is offline
post #8 of 16 Old 01-02-2006, 10:00 AM Thread Starter
OshinDivr's Avatar
Pacebria, I'm running the stock bottom end, and stock heads.
Jormungand, let me try to do this from memory...not quite sure what the abbreviations mean...
SAE numbers are corrected to a particular altitude and atmospheric condition if I'm not mistaken. Where STD is the actual output of the vehicle at that moment under the weather conditions at that point in time. The dynojet numbers are simply that. The superflow dyno gives you an approximation of what the car would have made on a "dynojet" dyno.
Hope this is somewhat correct.
1991 LX - Turbo 5.0
post #9 of 16 Old 01-02-2006, 10:48 AM
Nice for stock heads!
What cam? rockers?
MOOVS is offline
post #10 of 16 Old 01-02-2006, 11:18 AM Thread Starter
OshinDivr's Avatar
B303 cam, and Crane 1.6 rr's. There's still plently of power left on the table with some better heads, a more turbo friendly cam and of course more boost. I'm going to leave it as is for awhile though.
1991 LX - Turbo 5.0
post #11 of 16 Old 01-02-2006, 07:46 PM
your using an electric boost guage? i have heard nothing but bad about those.
stangbro01 is offline
post #12 of 16 Old 01-03-2006, 10:19 PM
wldtang's Avatar
Trader Feedback: (146)
So was your numbers 467 at 11 lbs or 411?
1994 Cobra Ex-Terminator - sold
2004 DSG Mach1 & 2003 DSG Cobra - sold
1990 Coupe Coyote swap - daughters car
1966 fastback terminator swap in progress
wldtang is offline
post #13 of 16 Old 01-04-2006, 09:41 AM Thread Starter
OshinDivr's Avatar
1991 LX - Turbo 5.0
post #14 of 16 Old 01-06-2006, 09:25 PM
Glad to hear you got it all lined out.
I cant wait to get mine finished up and to the dyno, im running a pretty similar setup. Stock 88 bottom end, B-cam stock heads and a T-72
03BlackWidow is offline
post #15 of 16 Old 01-06-2006, 09:33 PM
wldtang's Avatar
what do they charge for a dyno?
wldtang is offline
post #16 of 16 Old 01-09-2006, 08:58 AM Thread Starter
OshinDivr's Avatar
www.speedydyno.com
All their pricing is on their site there. If you contact them, talk to Greg or Sean.
1991 LX - Turbo 5.0
