Shortie headers -- Sufficient for turbo manifolds? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 12-21-2005, 08:35 PM Thread Starter
Formerly Blue93Trunk
Blu92GT's Avatar
I've got a set of 1 5/8'' primary shortie headers that I'm going to try to use. A friend that's going to build the kit for my car says they'll work. Would these be suffient enough?
Or should I opt for some manifolds elsewhere? If yes, where can I get some quality manifolds, that aren't hella expensive?
Thanks,
-Anthony-
00' Lightning -- Basic Bolt-ons. DD For Now...
Blu92GT is offline
post #2 of 13 Old 12-21-2005, 09:18 PM Thread Starter
Blu92GT's Avatar
Blu92GT is offline
post #3 of 13 Old 12-21-2005, 10:06 PM
gt93mustang's Avatar
Unless you are wanting to build something that makes 1200+ horsepower, they'll work just fine. Go for it!
gt93mustang is offline
post #4 of 13 Old 12-21-2005, 10:29 PM
Trader Feedback: (172)
They will work perfect
99 4V GT VERT
autosay97 is offline
post #5 of 13 Old 12-22-2005, 03:09 AM Thread Starter
Blu92GT's Avatar
How much of a difference would those 1 3/4'' Bassani/AFM short tube headers make, as compared to the 1 5/8''?
Blu92GT is offline
post #6 of 13 Old 12-22-2005, 08:59 AM
Erich's Avatar
I would not waste my time getting other non-turbo headers than you already have. What you have will work fine. If you want to spend some more money, B&G custom turbo makes a really nice set of turbo headers. This will fix the position of your turbos in a way that will work for sure for fabbing the rest of the setup. THAT is an advantage. Also, one less thing to build.
I think they are like 300 - 350 bucks.
Erich
Erich is offline
post #7 of 13 Old 12-22-2005, 11:35 AM
They would make a difference in that they would be a PITA to get on there, may not even worked flipped. Plus with a turbo you do not need the biggest tube header in most applications, it could even possibly hurt a little. I would use the shorties you have over those log headers posted above.
post #8 of 13 Old 01-02-2006, 11:20 AM
I used flowtech 1 5/8" on mine but I wouldn't recomend this to anyone as I am currently making another set from scratch.I got them cheap but man what a PITA to take off and put on as I had a leak problem with the pass side header.
I'm using a 3/8 flange this time(over 1/4") and trying to place primaries as to allow easier access to the header bolts.
Also the flowtechs have a more round port opening which I never liked.
JMO if your shorties are flowtechs.
MOOVS is offline
post #9 of 13 Old 01-02-2006, 06:13 PM
ony use bbk or motorsport stainless,they wont crack and built way better,mac suck they will start cracking been there done that,you get what u pay for
platedturbonotch is offline
post #10 of 13 Old 01-02-2006, 07:48 PM
just buy a set like the b&g set above, they are proven to fit and work and will save you alot of headaches
stangbro01 is offline
post #11 of 13 Old 01-18-2006, 02:23 AM
does b&g have a website
97 rio red cobra. Custom hpipe with high flow cats, Custom 2 1/2 exhaust with hooker aerochambers, mac underdrive pulleys, steeda triax, fms c springs SOLD
1991 Black notch in the works
venom281 is offline
post #12 of 13 Old 01-18-2006, 02:57 AM
post #13 of 13 Old 01-18-2006, 06:26 AM
my friend made 720 to the wheels on cft's dyno with flipped shorties and a home fabbed kit. and a gt42
I'm running a much smaller turbo with shorties (tried to use equal length, what a pita) make sure you don't run equal length whatever you do, mine should come in right around 450 on a mild h/c/i setup
1 bad Mustang, 2 slow Z28's, and a Sierra crewcab for the groceries.
Racenrik is offline
