Twin turbo help - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 12-10-2005, 06:46 PM Thread Starter
Twin turbo help
I'm new with turbo's, I've sold my old 306 blower combo to start on a new 351w twin turbo setup. I have a 351 roller bored 30 over with afr 205's and a trick R intake. Just need help with injector, mass air, and Tb size. And also what turbo's do you reccomend? Thanks, Jeff
I have 30lb inj and a 75mm mass air and tb already, will they be ok?
green91stang is offline
post #2 of 9 Old 12-10-2005, 10:23 PM
Erich's Avatar
You will need bigger injectors. 42s at least. The smallest turbos you want would be the T3 60/63s.
Erich
Erich is offline
post #3 of 9 Old 12-10-2005, 10:57 PM Thread Starter
Thanks Erich, i'll have to start looking....
post #4 of 9 Old 12-11-2005, 10:20 AM
Erich's Avatar
These guys http://www.westcoast-turbo.com/turboa.html and blaast performance seem to have good prices. I never bought from them so I can't vouch for anything but something to look at anyway.
Erich
Erich is offline
post #5 of 9 Old 12-11-2005, 11:09 AM
wow erich, they have some pretty kick ass prices......
wyominghotwheels is offline
post #6 of 9 Old 12-12-2005, 07:00 AM
Erich's Avatar
When I see like 300 something for a 60/63 garrett and I know I paid 100 for the turbo then 128 for a rebuild kit then 35 to get the wheel balanced AND it is an IHI, it makes me feel a little uncomfortable!
Erich
Erich is offline
post #7 of 9 Old 12-12-2005, 07:02 AM
Erich's Avatar
double post
Erich is offline
post #8 of 9 Old 12-12-2005, 07:24 AM
xr8240's Avatar
They seem alittle small though...
How about these..They are higher flowed T3/4 units..
http://www.pagparts.com/perfpts1.asp...&cat=sportt3t4
xr8240 is offline
post #9 of 9 Old 12-12-2005, 08:44 AM
strokercharged95GT's Avatar
a turbo 351 will require bigger than 42's, hell i have to run an FMU to get enough fuel up top with my 347 blower combo. Id look at some 60's
2013 Mercedes GLK-350
strokercharged95GT is offline
