What kind of BOV is this??? And what are the holes for?*pics* - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 12-04-2005, 05:12 PM Thread Starter
Saleen S351's Avatar
I bought this turbo kit off of corral and the guy didnt send me any directions. This is my first time dealing with turbos and setting one up. All i need to know is what are the two holes at the top (or facing the ground as this setup is) of the BOV is? And there is a threaded line on the side also that i have connected to a hole that was ported into my turbo. I dont even know if that goes there. So any help or comments will help me greatly......
Here is the threads on the side that i have the braided line from the turbo going to..
Saleen S351 is offline
post #2 of 12 Old 12-04-2005, 06:11 PM
I'm new to this but that looks like a wastegate to me. But as i understand that line is run correctly just leave the top open.
Your bov will go between the turbo and your TB on your intake piping.
03BlackWidow is offline
post #3 of 12 Old 12-04-2005, 07:43 PM
Its a wastegate, the hole off to the side if for a filter(bronze I think). The threads are for adjusting when the wastegate opens = boost setting. The braided line that goes from turbo to wastegate is what sends boost pressure to the wastegate.
warlock1313 is offline
post #4 of 12 Old 12-04-2005, 11:17 PM Thread Starter
So do i need a blow off valve for this setup?
post #5 of 12 Old 12-05-2005, 12:48 AM
I would think so, they say you will spin your turbo backwards. You close your tb blade and all that air has to go somewhere.
post #6 of 12 Old 12-05-2005, 03:17 AM
A BOV or Bypass depending on if you have a MAF and where its placement is in the sytem.
mfpmax is offline
post #7 of 12 Old 12-05-2005, 09:07 PM Thread Starter
what kind and where is a good place to get one? e-bay?
post #8 of 12 Old 12-06-2005, 04:13 PM Thread Starter
anyone know?
post #9 of 12 Old 12-06-2005, 11:40 PM
Are you going to be running a blow-thru or a draw thru MAF setup?
If you're doing a draw-thru you'd probably want a Bypass.
http://www.forgemotorsport.com/index.asp
This company has some nice Bypass and BOV valves...quite expensive though. A cheap alternative is of course a standard Bosch valve.
If you're running a blow-thru a good high flow BOV is a Tial.
http://www.tialsport.com/
Also check the classifieds section here for people selling their old stuff such as Vortech Bypass valves from supercharger kits.
mfpmax is offline
post #10 of 12 Old 12-07-2005, 01:28 PM Thread Starter
which one is better? im getting 42lb injectors for this setup also.
post #11 of 12 Old 12-07-2005, 05:53 PM
what do you exactly mean which one is better?
slowjoe is offline
post #12 of 12 Old 12-07-2005, 11:55 PM
I don't think there is a "better"...pick which one comes with the most attachments or something...
mfpmax is offline
