Hellion DYNO results... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 21 Old 12-04-2005, 05:03 PM Thread Starter
LilMayo's Avatar
Stock motor, 200k miles, mods in sig.
The car put down 405hp and 443tq. 9lbs of boost and a/f right at 11.0. The timing was locked at 15* and fuel pressure at 32psi. Ill post a vid and a pic of the dyno sheet when I get it uploaded. Tell me what yall think.
mat
1990 Mustang Coupe 5.0 5spd
LilMayo is offline
post #2 of 21 Old 12-04-2005, 05:11 PM
thats good numbers for the mods what did the turbo kit cost complete if you dont mind me asking and did you put it on how long did it take you.
dowdytime is offline
post #3 of 21 Old 12-04-2005, 06:27 PM
This is lilmayo but im at a buddys house on his name, $5000, the only things i bought besides the kit was a boost and fuel pressure gauge and a fuel pressure regulator. It took me about 2 weeks working a few hours a day due to being at school from 7:30-12:45 and working.
90mach is offline
post #4 of 21 Old 12-05-2005, 01:05 AM Thread Starter
LilMayo's Avatar
Here's a vid of the car on the dyno.
http://www.supload.com/vid/TurboStan...413431342/wmv/
mat
LilMayo is offline
post #5 of 21 Old 12-05-2005, 09:11 AM
great numbers man............
wyominghotwheels is offline
post #6 of 21 Old 12-05-2005, 09:38 AM
Corral Charter Member
Chris89Stang's Avatar
What turbo are you running?
Chris
1989 Mustang LX - small turbo
2016 Explorer Sport - a couple of turbos
Chris89Stang is offline
post #7 of 21 Old 12-05-2005, 03:51 PM Thread Starter
LilMayo's Avatar
T-62, basic turbo in the Hellion kit.
mat
LilMayo is offline
post #8 of 21 Old 12-05-2005, 06:36 PM
TBAG's Avatar
wow, I want one bad!!!
TBAG is offline
post #9 of 21 Old 12-05-2005, 08:28 PM Thread Starter
LilMayo's Avatar
It's a great kit if I had to do it over again I wouldn't do it any other way. Even Mike Wilson at Dallas Mustang, the guy that tuned it, was very impressed. It's also a pretty conservative tune with only 15* of timing and the a/f at 11.0 but with the miles on the motor i wanted to keep it safe, when i get a new motor i think ill turn the timing up and lean it out a little more just to see what it'll do with the stock motor. O yea btw no chip was required to tune it which was really a plus.
later
mat
LilMayo is offline
post #10 of 21 Old 12-06-2005, 09:42 AM
mat
Nice #'s. What psi? and are those Dynojet #'s?
Chris
post #11 of 21 Old 12-06-2005, 04:41 PM Thread Starter
LilMayo's Avatar
9lbs, Im pretty sure it was a dynojet but i accidently left the dyno sheet up there in dallas and I'm waiting for them to email a copy of it.
mat
LilMayo is offline
post #12 of 21 Old 12-11-2005, 10:39 PM
I have the same Hellion kit. Were you able to run the underdrive pulleys? I couldn't get them to work with my kit (any ideas...not that it matters much though with the turbo).
I have H/C/I and am running 9#s of boost. I can't keep the tires from spinning through out 2nd gear and in third at times. Though the nittos are from from new, the car is a beast. Install was easy like Mat said.
For the time being, I am going to drop down the the 5# spring and see how much HP I can get from it. I am only wanting to run about 400-425 RWHP so I can hook killer.
Nice numbers Mat.
E.J. is offline
post #13 of 21 Old 12-11-2005, 11:21 PM Thread Starter
LilMayo's Avatar
Nice numbers Mat.
Hey E.J. i still have my underdrives, wut exactly do u mean by they wouldnt work? what h/c/i combo ru running and hav u put it on the dyno?
later
mat
LilMayo is offline
post #14 of 21 Old 12-12-2005, 09:18 AM
I couldn't get the idler tension puelly to work with the larger water pump pulley. I tried the shortest belt possible so the tensioner wouldn't touch the water pump pulley. I did just hear of another guy who was able to get his to work. I guess I should go back and try something else.
No dyno numbers yet. I was suppose to go race in Bradenton, FL this past weekend, but because of several things going wrong with the car last minute, she is up on jack stands in the garage. I did just install an Innovate WB O2 and MSD digital 6+. I am attemtping to tune the car with an Apexi AFC (the ricers love those things). If it doesn't work, I am going to get a chip.
I have Edelbrock Performer heads & intake and an E-303 cam. I also have a 70MM TB and 3.73 gears. Other than that, it's all she's got besides some suspension work and subframes.
E.J. is offline
post #15 of 21 Old 12-12-2005, 11:15 PM
S-Trimmed302's Avatar
Trader Feedback: (124)
Are you running the exhaust through the Tailpipes or Dumped from the mufflers?I am looking for somebody thats running a Hellion kit or an HP kit that has their exhaust Dumped right outta the header exiting from an open downpipe..Car sounds/Revs awesom.! Congrats..
My 92 Coupe- Under construction - Dart 347, TFS 205 11R heads,Custom Cam by Brian Friedentag "freezy74",TFS Box R Intake, 75mm Accufab TB, Hooker Supercomp 1 3/4" Full Lengths,Vortech Pass side YSI,8" Crank,2.85 blower pulley,Treadstone 1245-28 Intercooler,Snow Stage 2 Meth kit
S-Trimmed302 is offline
post #16 of 21 Old 12-13-2005, 12:29 AM Thread Starter
LilMayo's Avatar
At first i had teh 2.5" bullets turned down but today i got a straight through resonator off a dodge hemi welded up and a single pipe that exits in front of the pass side rear tire, a lot less restrictive, louder, and u can hear the turbo now inteh exhaust. ...so much for the sleeper effect
mat
LilMayo is offline
post #17 of 21 Old 12-13-2005, 10:28 AM
That sounds awesome lilmayo............git r dun
post #18 of 21 Old 12-13-2005, 03:38 PM
OshinDivr's Avatar
I'm running the 5lb. spring in the wastegate right now, and I have no traction either. First with some fairly worn BFG DR's, then with some Kumho's...she spun regardless. So good luck with that. I'm switching to some 3.27's in the next day or two hoping that helps some.
1991 LX - Turbo 5.0
Old Combo...Stock block and heads, Turbonetics 62mm...6.78 @ 104.25 - 436rwhp/508rwtq @ 10psi
New Combo...Boss 347, TW heads, Super Victor, Cam Motion cam, Precision 78mm, Big Stuff 3, etc...
OshinDivr is offline
post #19 of 21 Old 12-14-2005, 11:24 AM
later
mat
Once to the point of having a power adder, especially a turbo, underdrive pulleys help so little for the over all power that they should just be swapped for stockers. They cause more issues with cooling the motor and charging the battery than it is worth. Plus chances are someone would give a 20 spot or maybe a little more for them and give a set of stock pulleys to put onto the car.
post #20 of 21 Old 12-14-2005, 05:31 PM
I have removed all of my underdrive pulleys after installing my turbo kit. I initially tried to keep the waterpump and crank pulleys, but due to cooling issues I went back to stock.
At 13psi, I can assure you they are not missed.
1990 Mustang GT, Explorer shortblock with DSS MSS, Edelbrock Performer RPM heads, stock GT cam with 1.72RR, ported Explorer intake and 65mm TB, PTK T66 kit @ 18psi, AEM EMS + WBO2, Alkycontrol methanol injection: All Sold
Cld12pk2go is offline
post #21 of 21 Old 12-14-2005, 06:40 PM
nice #'s... that timing is a little conservetive, i run 20* locked with 14psi on 93 octane-stock motor and 17psi with some good gas, i cant wait to see what my car lays down in the spring!! i also plan on adding nitrous.
stangbro01 is offline
