HY-35 VS. HX-35 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 11-26-2005, 02:18 AM Thread Starter
HY-35 VS. HX-35
ok I just want to make sure it will spool up before u know like 6500 rpm its a street car so i want it to spool between like 3 an 4 grand. Also if you have any opinions on how big i could go an still get it to spool in that rpm range that would be sweet. only one turbo. Also i have a carb anyone know of a good blow through carb? thanks ahead of time.
Simon Roth
Source Automotive.
simon445 is offline
post #2 of 7 Old 11-26-2005, 10:22 PM
sup simon......
Most turbo's tend to spool in the range's you are desiring.....i don't think that will be an issue for you at all........You will probably never again have to go over 6,000 rpm to be fast, once you get your tubo's installed.....
are you interested in doing your own carb work or do you just want to buy a carb?
wyominghotwheels is offline
post #3 of 7 Old 11-26-2005, 10:42 PM Thread Starter
I dont know how to work on carbs. once again im only 15 so im still learning. but if you have a website that has race blow through carbs that would be sweet. I was thinking about doing an hx-35 dodge-zilla which is a stock turbo built up for the diesels. so i figure if i can get the thing to spool i would be able to get 500 hp. at the most im still running a stock block an short block an heads everything other than carb intake an cam. so i just want to practice an get a turbo set up. then after i get the turbo i will be upgrading the engine rearend an transmision.
simon445 is offline
post #4 of 7 Old 11-26-2005, 10:57 PM
schweet man, great to have someone young, studing to turbocharge....welcome to the insanity of power.....hehehehehe
here is some good reading material for ya: http://www.hangar18fabrication.com/blowthru
post #5 of 7 Old 11-27-2005, 12:14 AM Thread Starter
ok dude that sounds good. what is a good intercooler. how much boost should i run. an also what other small things will i need? who makes good wast gates? thanks
simon roth
source automotive
simon445 is offline
post #6 of 7 Old 11-27-2005, 03:10 AM
Spearco Intercooler's rock....
9 to 10 psi would probably work.
tial
1 step colder sparkplug's, a carb bonnett.....there is probably alot more, but you get the picture....
post #7 of 7 Old 11-27-2005, 08:36 AM
And an TON OF RESEARCH.
10secgoal is offline
