will this turbo be large enough for my goals? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 11-21-2005, 08:44 PM Thread Starter
It is a t67 with .68 ar housing. I wanted at least 500rwhp. is this attainable??
fastwhite86gt is offline
post #2 of 10 Old 11-22-2005, 08:29 AM
I would say yes...........had a friend of mine with a T60-1 and it dyno'd out at 504hp..........
wyominghotwheels is offline
post #3 of 10 Old 11-22-2005, 09:16 AM
Yes it is attainable, didn't you ask this in another thread already?
post #4 of 10 Old 11-22-2005, 10:51 AM Thread Starter
yes but i was getting no response. I have my setup in the other thread and wanted to know if it was possible ( TW heads, stock cam with 1.72 rockers, cobra intake)
post #5 of 10 Old 11-22-2005, 02:24 PM
and the answer is still yes, especially with the tw's..........you should be good to go, and more then likely still have room to play if you want.....fuel will probably be your limiting factor......
post #6 of 10 Old 11-22-2005, 02:27 PM
Will the answer change to no by your third post replying to the same thread?
post #7 of 10 Old 11-24-2005, 01:53 PM
Yep. I've seem to obtained that rather easily
rippy is offline
post #8 of 10 Old 11-24-2005, 01:55 PM
damn, awesome numbers rippy..........damn
post #9 of 10 Old 11-24-2005, 02:40 PM
rippy put some slicks on that thing you will be in the low 11's maybe high 10's
Bostang is offline
post #10 of 10 Old 11-24-2005, 02:44 PM
Next year its getting a dart block with a stroker kit, bigger fuel system and drag radials.
rippy is offline
