Hellion Dyno Results... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 14 Old 11-21-2005, 09:47 AM Thread Starter
OshinDivr's Avatar
Well, the car is tuned, and I'm a tad let down, yet fairly happy at the same time. The car made 335rwhp & 386rwtq @ 10psi with a 5lb. spring in the wastegate. EGT's were actually dropping at WOT. We're thinking the B303 might be hurting the power level some due to not enough lobe separation, and there is anywhere from 70 to 100+ rwhp left on the table. The car is by no means a pig, but just didn't make the power I was expecting. Regardless, its nice to have a running turbo car sitting in the drive.
Here's a vid...
https://s40.yousendit.com/d.aspx?id=...M3JLOYDUIU8Q8Y
And another...
https://s40.yousendit.com/d.aspx?id=...T218JIB3VAUD8W
1991 LX - Turbo 5.0
Old Combo...Stock block and heads, Turbonetics 62mm...6.78 @ 104.25 - 436rwhp/508rwtq @ 10psi
New Combo...Boss 347, TW heads, Super Victor, Cam Motion cam, Precision 78mm, Big Stuff 3, etc...
OshinDivr is offline
post #2 of 14 Old 11-21-2005, 10:12 AM
Yes the B303 is hurting you, a stock cam would make more power with the turbo setup than a B303. Swap it out to a F303, E303, or a stock cam for a cheap swap that will work well with the turbo.
post #3 of 14 Old 11-21-2005, 10:28 AM Thread Starter
OshinDivr's Avatar
Snipe, and suggestions on where to start researching a good custom grind??
1991 LX - Turbo 5.0
post #4 of 14 Old 11-21-2005, 10:32 AM
Cam Motion comes highly recommended for a custom grind turbo spec cam.
post #5 of 14 Old 11-21-2005, 11:35 PM
jw33's Avatar
Did they just kill the motor right after the pull in the first video??? That's real good for the turbo's bearings....
jw33 is offline
post #6 of 14 Old 11-22-2005, 10:51 AM
U.S. Air Force RETIRED
Matt Grieve's Avatar
Trader Feedback: (88)
I made 430/510 with the stock cam...granted I have GT40 heads and a cobra intake but they don't flow that great...
Put a stock cam in the car and go from there...
What was your f/p at? A/F ratio? Timing?
1990 Mustang GT
2004 Mystichrome Cobra
2015 Mustang Ecoboost
2015 RAM 2500 Cummins
Matt Grieve is offline
post #7 of 14 Old 11-22-2005, 11:02 AM Thread Starter
OshinDivr's Avatar
I've got a ported Cobra upper and lower, and the E7's are ported as well. There are a few other mods too. I talked to Urist yesterday, and he's thinking there's something not hooked up right in the kit, and that the cam isn't robbing that much power. I think he's right. I'm going to recheck everything, and go from there. I'm probably going to stick a mechanical boost gauge on there to see if the electrical one is reading right. Like I mentioned above, it has the 5lb. spring in the gate, but the gauge is reading 10-11psi. The numbers it made on the dyno would be about right if it was actually making 5-6lbs. of boost. Not exactly sure what the f/p and timing are at now since it was done through the tune. Prior to that, it was locked at about 17 degrees with the spout out, and f/p was was set around 34psi. My a/f ratio is right around 11.8-11.9 across the board.
1991 LX - Turbo 5.0
post #8 of 14 Old 11-22-2005, 12:16 PM
All I can say is I have watched people who had B303 cams swap back to stockers on turbo apps and end up gaining a huge amount of power. Usually in the tq department more so than the hp department. So even if something is hooked up wrong, I would still swap out that cam because it is not a helpful cam for a turbo app.
post #9 of 14 Old 11-22-2005, 01:02 PM
What was your EGT readings at? Where they taken at the turbo, headers, or downpipe? I assume you got a custom chip with a A/F reading through the pull.
Eric
Black 93GT, Single Precision 7675, 308 Mexican block, F cam, AFR 195's, 75mm TB, 1.7RR, 60's, BA5000 MA, Crane Hi-6, LX-92 Coil, S/N 95 Rails, Kirban FPR, 255 inline/255 intank, aluminum radiator, Countour Fan, Police Oil Cooler, 3.31 gears and a 5 speed.
post #10 of 14 Old 11-22-2005, 01:13 PM Thread Starter
OshinDivr's Avatar
EGT is reading from the headers, and would get as high as about 950 degrees, and then start dropping. They'd get down to like 570 or so degrees. Yes, I have a custom chip.
1991 LX - Turbo 5.0
post #11 of 14 Old 11-27-2005, 07:43 PM
BAERSysteMAX's Avatar
Trader Feedback: (33)
stock cam is where its at my friend, i put down 625 rwhp so far on one at 18 psi.
90 lx 5 speed... 10.5 @ 136 stock bottom end and cam... ford junk !
86 gt ttop
90 coupe [email protected] turbo pump gas street car
BAERSysteMAX is offline
post #12 of 14 Old 11-30-2005, 08:09 PM
on race gas tho dave? or on pump? and not PUMP as is PUMPed out of the 114 drum lol
mattred90gt is offline
post #13 of 14 Old 12-01-2005, 07:07 AM
Your numbers sound just right for 5 psi.
My Autometer boost gauge reads 2-3 psi higher than my AEM MAP sensor...
Cld12pk2go is offline
post #14 of 14 Old 12-05-2005, 12:18 PM
Here's a vid...
And another...
Damn. Your stang looks exactly like mine (minus the rims). That sounds good with the turbo, and if you could get that extra 100 hp out of it, it'd be a beast.
Jaggezz is offline
