turbo & Gt40p heads?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 10-18-2005, 04:08 PM Thread Starter
madmaxin22's Avatar
im considering selling the s/c and going turbo route. Is there any way to even turbo a 5.0 w/ the gt40p heads. They need specific headers for the plug angles as it is, so is it impossible to run these heads w/ a turbo without going into custom manifolds??
2011 GT 6spd-stock
2010 Ram Hemi Crew-CAI,sc tuner,magnaflow
madmaxin22 is offline
post #2 of 5 Old 10-18-2005, 06:23 PM
SN95LEEN's Avatar
It depends.
I ran a TTI kit w/a P specific driver side header, the log manifold worked fine. If you're going the twin route, you need to find out what manifolds they're using, are they built in-house or are they using someone else's? There's no easy answer, you have to mock it up w/the manifolds you'll be using to find out.
SN95LEEN is offline
post #3 of 5 Old 10-18-2005, 09:33 PM Thread Starter
madmaxin22's Avatar
im just gonna sell off the heads and start fresh from scratch.... thx
2011 GT 6spd-stock
post #4 of 5 Old 10-19-2005, 08:07 AM
Erich's Avatar
Don't do it! P heads are great for this application. I have em on mine. Flipped shorties are better with the Ps. I have a bunch of photos of the same flipped headers on both. Also, with the Ps, you use 90 degree angled plug wires and everything fits against the valve cover, No floppy loose burnt wires. My car is making nice power even on an incomplete dyno run.
Erich
Erich is offline
post #5 of 5 Old 10-19-2005, 12:54 PM
Erich's Avatar
Pictures of E7 versus GT40P heads
Here are two comparisons showing the plug location of E7 heads and GT40P heads relative to stock mustang headers that are flipped and modified to accept T3 turbos. What you can see is that the P heads are actually better for plug clearance: the plugs go nicesly under the tubes.
Erich
Erich is offline
