Turbo Mustang Idea for carb'd car... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 10-17-2005, 05:07 AM Thread Starter
I'm new to the whole concept of turboing a carbd car but I am under the impression that if you make a sealed box around the carb it allows you to run a turbo...
am I completely wrong? is it far more complicated than that?
Could I build a large aluminum box with a mount that allows the entire carb into the box, then ontop have a valved door to allow you movement inside the box? as long as its air tight and any line in or out is gasketed it should remain at a constant pressure right?
now if this is a sound way of doing it, would I just run a larger carb, say its a 306 i run an 1150 carb or something...?
I know this could potentially make me sound like an idiot but I am usually a all motor guy, just because i could never afford a turbo car... any help on my thoughts would be greatly appreciated, im just trying to get a better understanding of a carb/turbo set up...
thanks again,
Kyle
turbodsomeday is offline
post #2 of 3 Old 10-17-2005, 01:50 PM
http://hotrod.com/techarticles/79738/
mfpmax is offline
post #3 of 3 Old 10-17-2005, 04:46 PM
You need to visit the carb section over on www.turbomustangs.com/forums . Theres a lot of good info on setting up a blow thru carb setup.
Alain K is offline
