Looking for help on my 4.6 SOHC single turbo set up. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 22 Old 10-10-2005, 01:58 PM Thread Starter
DNA
Anyone out there have some good information for me? I want 600HP to the wheels.
DNA is offline
post #2 of 22 Old 10-10-2005, 11:27 PM
www.turbomustangs.com
sportsroof69 is offline
post #3 of 22 Old 10-11-2005, 12:22 PM
Pick a turbo kit, buy a built shortblock and be prepared to beef up the tranny and probably rear end.
post #4 of 22 Old 10-11-2005, 11:04 PM
What do you want to know?
'95 GT
-DSS low comp. 306/GT-40Y/Cobra U/L
-DIY Single Turbo - Holset WH1E @ 7psi intercooled
Powershift95GT is offline
post #5 of 22 Old 10-12-2005, 10:30 AM Thread Starter
DNA
I need to get a set of Turbo Cams
I all ready have a fully forged bottom end, ARP studs thru out with a DSS girdle. I have a Bullitt intake and am going with 60 Lbs inj. running a T-76 mm single kit and I would like to know who is running stock PI cams or custom cams. Modular Powerhouse has a set but they are like three month lead time to get.
DNA is offline
post #6 of 22 Old 10-12-2005, 11:31 PM
y2k02's Avatar
I have stock cams, stock lower intake and Patriot stage II heads. It's making 539rwhp & 586rwtq.
2002 2V TF heads Custom Edelbrock NA SVT Cams
Twin 6466 TH400 Dominator EFI TH400 UCC
y2k02 is offline
post #7 of 22 Old 10-13-2005, 08:32 AM Thread Starter
DNA
y2k02
When does your full boost come on?
DNA is offline
post #8 of 22 Old 10-13-2005, 10:32 PM
y2k02's Avatar
I'm seeing 15psi at 3200rpm.
y2k02 is offline
post #9 of 22 Old 10-14-2005, 09:46 AM Thread Starter
DNA
Twin or single
Is your the twin kit?
DNA is offline
post #10 of 22 Old 10-14-2005, 10:27 PM
y2k02's Avatar
y2k02 is offline
post #11 of 22 Old 10-18-2005, 08:33 PM
lol...
killerbox is offline
post #12 of 22 Old 10-19-2005, 08:31 AM Thread Starter
DNA
yeah yeah
Helps if I read the sigs huh?
More parts are on there way in.
DNA is offline
post #13 of 22 Old 10-20-2005, 08:23 PM
You should give MM Performance a call. They have done some turbo kits. I think right now they are doing one 2v Jack Roush and an 04 Cobra with Twin 67's. That should be a fun ride. LOL. They just became Dealers for HP kits know I beleive. If you feel like giving them a call here is their number: 704-309-5357 ask for Will. The specialize in 4.6 and 5.4's. I think they even did an twin turbo viper. Sorry can't be to much of help but they should be able to help you out with some questions that you have.
TOXIC 5.4 is offline
post #14 of 22 Old 11-18-2005, 10:08 AM Thread Starter
DNA
Car update
I just put in the purchase for the following parts;
Stage 3 heads (2 valve) oversized valves *** retain etc..
Custom Comp Turbo cams
Snow Perf inj kit
SCT Mass Air
60 lbs inj.
sumped fuel tank
Billet rails
sfi damper
EGI stand alone system
Turbosmart b/c
Moroso 7 QT pan
BFG 315/35/17 DRs
50 shot N2O
DNA is offline
post #15 of 22 Old 11-29-2005, 09:02 PM
DV19's Avatar
Snow Perf inj kit
SCT Mass Air
60 lbs inj.
sumped fuel tank
Billet rails
sfi damper
Turbosmart b/c
Moroso 7 QT pan
BFG 315/35/17 DRs
50 shot N2O
I'll be interested as to how all that blends together..... I'm doing a similar project and it looks like we'll have very similar motors..... I'm going with an Aluminum block and twins.... Keep us posted, DV
DV19 is offline
post #16 of 22 Old 11-30-2005, 05:23 PM Thread Starter
DNA
Ignition system ordered
I just ordered the Full MSD system;
DIS4 HO
MSD Coil Packs
MSD Wires
MSD Window switch for second fuel pump.
DNA is offline
post #17 of 22 Old 12-04-2005, 12:43 AM
grayson404's Avatar
HA HA! I know who you are!
MM is doing my TT setup as we speak/type/whatever. In addition he's building the bottom end, rear end, heads, fuel system, front suspension, rear suspension, cage, etc. From the turbos to the cage, it's all custom. No cookie cutter kits here. There're even some experimental things going on that could give more performance options for the 2v guys and the mod motor community in general. Stay tuned.
Jay
grayson404 is offline
post #18 of 22 Old 12-08-2005, 02:21 PM Thread Starter
DNA
Anyone want to start guessing HP numbers?
OK I go get the parts this Saturday. And Im going to go thru and make sure everything fits and looks right and then I will start assembly.
What do you all think I can make with this.
92 octane
Snow Injection starts at 3 lbs boost reaches make injection at 10 lbs boost
Air/Air Spearco rated at 1000 HP
14-16 PSI boost is my target
TKO 600 tranny
Downpipe dumps out under front fender.
DNA is offline
post #19 of 22 Old 12-11-2005, 02:12 PM
What's the "EGI stand alone system"?
2004 Redfire GT...PTE billet 71mm Turbo/Forged Alum. shortblock, custom cams, P51****sold to fellow Corraler****
2014 SGM A6 GT [email protected] CAI, Tune, off-road X, 19" DR's. Twin turbos coming for the fall of 2013.
WIPLASH1 is offline
post #20 of 22 Old 12-12-2005, 12:57 PM Thread Starter
DNA
EGI should be EGT sorry
It is an EGT monitoring system
DNA is offline
post #21 of 22 Old 12-18-2005, 03:11 PM
DNA, you'll need about 100-105#'s of seat pressure on your exhaust, especially with oversized valves.
WIPLASH1 is offline
post #22 of 22 Old 12-19-2005, 09:29 AM Thread Starter
DNA
I was starting to read about some
Thanks I was starting to wonder about that. I have read a few posts about the exhaust seat pressures. I am going to check my Heads when they come in. Thanks for the set pressure range.
DNA is offline
